Torque management experts, is this TM?
Current Gear(.) Engine Speed(RPM) Ignition Timing Advance(°) Throttle Position Angle(%)
1 791.8 28 0
1 808.8 26.5 0
1 796.3 28.5 0
1 787 28.5 0
1 783.3 28.5 0
1 797.8 27 0
1 805.3 27 0
1 827.5 25.5 0
1 801.3 27 0
1 775.8 31 0
1 773 29 0
1 790 26 14.1
1 889.8 24.5 21.2
1 1405 25.5 28.2
1 1702.5 27 38
1 1972.8 27 45.9
1 2202.3 27.5 52.2
1 2378 27.5 63.1
1 2559 27 93.7
1 2908 24.5 100
1 3233.3 24.5 100
1 3608.8 24.5 100
1 3982.3 25 100
1 4412.8 25.5 100
1 4957 26.5 100
1 5390.8 27 100
2 5783.5 27 100
2 5911.3 27 100
2 4632.3 24 100
2 3288.5 24 100
2 3476 24.5 100
2 3555.5 23.5 100
2 3589.5 24 100
2 3650.8 24 100
2 3700.3 24 100
2 4008.8 25.5 100
2 3991.8 25.5 100
2 4100.8 25.5 100
2 4283 25.5 100
2 4462.8 26 100
2 4516.5 26 100
2 4642.3 26.5 100
2 4800 27 100
2 4917.8 27.5 100
2 5064 28 93.7
2 5190 29.5 35.3
4 4975 41 0
4 4610.8 41 0
4 4182 41.5 0.4
4 3869.3 41.5 0.4
4 3616.5 41.5 0
4 3334.8 41.5 0.4
4 3109.8 41.5 0.4
4 2711.5 40.5 0
4 2217.3 39.5 0.4
4 2140.8 39.5 0.4
4 2140 39.5 0.4
4 2126.8 39.5 0.4
4 2095 39.5 0.4
4 2096.5 39 0.4
4 2099 39.5 0.4
4 2094.5 39 0.4
4 2093.8 39.5 0
4 2086.3 39.5 0.4
4 2081.3 39 0.4
4 2063 39 0.4
4 2069 39 0.4
4 2058 39 0.4
4 2050 39 0.4
I just ATAPed a friends '02 TA Saturday at the track and he showed -10 timing just before the shift into second. Now that's TQM!
Example:
My car would do something like this on a shift:
24
24
24.5
-10
-10
-8
0
10
17
20
24.5
25
25
25.5
BTW: It's not incommon for timing to go to -10 on a shift for one maybe 2 frames on a stock PCM.. anything more isn't good.
If there is any question, get it tuned. I ran in circles for 6 months with this thing, and tried about everything... tuning was the only cure.
<small>[ July 15, 2002, 07:28 PM: Message edited by: WILWAXU ]</small>
Current Gear Engine Speed
1 606
1 617
1 1094
1 2934
1 3448
1 4134
1 4865
1 5208
1 5405
1 5527
1 5537
1 5450
1 5366
1 5630
1 5870
2 6170
2 5988
2 5527
2 4878
2 4840
2 4892
2 4952
2 5028
2 5086
2 5147
2 5201
2 5263
2 5308
2 5353
2 5419
2 5502
2 5586
2 5652
2 5714
2 5794
2 5848
3 5928
<strong>Funny you say that is I have tuning.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Well.. then you need to talk to whoever did the tuning. If the tuner wasn't asked to remove TM.. then it probably was left alone. Ed Wright got rid of mine completely!
Torque management is a function of the PCM that reduces engine power
under certain conditions. Torque Management is performed for the
following reasons:
To prevent overstressing the powertrain components.
To prevent damage to the vehicle during certain abusive maneuvers.
To reduce engine speed when the IAC is out of the normal operating
range.
The PCM monitors the following sensors and engine parameters to
calculate engine output torque:
Air/Fuel ratio
Mass Air Flow
Manifold Asolute Pressure
Intake Air Temperature
Spark Advance
Engine Speed
Engine Coolant Temperature
A/C Clutch Status
The PCM monitors the torque converter status, the transmission gear
ratio, and the engine speed in order to determine if torque reduction
is required. The PCM retards the spark as appropriate to reduce
engine torque if torque reduction is required. The PCM also shuts
off the fuel to certain injectors to reduce the engine power in the
case of an abusive manuever.
The following are instances when engine power reduction is likely to
be experienced:
During transmission upshifts and downshifts.
Heavy acceleration from a standing start.
The IAC is out of the normal operating range.
When the driver is performing harsh or abusive manuevers such as
shifting into gear at high throttle angles or shifting the
transmission from reverse to drive to create a rocking motion.
The driver is unlikely to notice the torque management actions in the
first two instances. The engine power output will be moderate at
full throttle in the other two cases.
The PCM calculates the amount of spark retard necessary to reduce
engine power by the desired amount. The PCM disables the fuel
injectors for cylinders 1, 4, 6, and 7 in the case of an abusive
manuever.
following reasons:
range.
Air/Fuel ratio
Mass Air Flow
Spark Advance
Engine Speed
A/C Clutch Status
be experienced:
manuever.
<small>[ July 19, 2002, 06:32 PM: Message edited by: 2xLS1 ]</small>
