Rear-End Help
Old Oct 31, 2006 | 06:51 PM
raceking33's Avatar
Default Rear-End Help
Hey guys I have been reading a lot on here and I am trying to figure out something still, when you say new rear end do you mean new housing and 3rd member and just 3rd member? I am do in a v6 to 383 swap in the future and just figuring out some numbers! also how much on average do you spend in a new rear end??? i am gonna run a spool. Thanks a lot!!!
Old Oct 31, 2006 | 08:05 PM
CW00BlackTA's Avatar
Usually people are referring to the whole thing (hub to hub). Depending on what you buy you can spend from $2-3K for new and $1200-2000 used--for something that will take some abuse.
Old Nov 1, 2006 | 05:20 AM
EPP's Avatar
EPP
Moser 12 Bolt with Truetrac for F Body, your choice of gear ratio
33 Spline Axles with 10 year warranty
ABS (3 channel) or ABS/TCS (4 channel)
Performance aluminum cover
$2,350.00 plus Freight Collect Shipping
Moser 9 Inch with Truetrac for F Body, your choice of gear ratio
31 Spline Axles
$2,400.00 Shipped by UPS
31 Spline Axles
ABS/TCS (4 channel) 3 channel not offered
$2,500.00 Shipped by UPS
Moser 9 Inch with spool, your choice of gear ratio
35 spline axles
Aluminum center section
$2,250 shipped by UPS
Moser 9 Inch housing and axles with torque arm bracket
Your choice of axle spline
Narrowed housing, no extra charge.
$1,000.00 shipped by UPS
Call us at 260 244-4808. Rear ends are ready to ship two days after order is received. Bob
Old Nov 1, 2006 | 07:48 AM
Firechikn's Avatar
Yeah, and add another 1000-1500 for all the suspension upgrades, and you'll be set. And maybe a new drive shaft.
