Pain in the ass
Old Nov 1, 2006 | 09:14 PM
camarojunky74's Avatar
Default Pain in the ***
okay so i have the whole rear end apart in my shop except for taking ou the pinion. and there is still no visible reason that. "A" only two tires spin during a burnout when they want and "B" why my car shakes ridicuaously bad during a burn out like so bad i think the wheels could pop off and my **** explode... lol im looking at all the worm gears looking at the axles pinion ring gear you name it it looks to be in good shape. the rear end doesnnt make noise or vibrate until you do a burn out this is pissin me off i cant figure it out.
Old Nov 1, 2006 | 10:56 PM
jebcamaro's Avatar
All that vibration is called wheelhop. Wheelhop has nothing to do with the internals of your rearend. I suggest you put it back together. You need to upgrade your rear suspension components to combat the wheelhop your experiencing.
Old Nov 1, 2006 | 11:34 PM
LS1powerhouse02's Avatar
i agree with the above post. The "wheel-hop" you are feeling is caused by your suspension......or lack thereof. Upgrade your suspension with some Lower Control Arms, Panhard Rod, springs, and shocks. A torque arm wouldn't hurt either. I just have BMR LCAs and PHR and i dont have wheelhop anymore.
Old Nov 2, 2006 | 12:03 AM
chuckyt1's Avatar
If it is wheel hop - Check the pinion angle, and put on some LCA relocation brackets also. Just my .02...
Old Nov 2, 2006 | 03:25 PM
well i was thinking that, cause i had the same problem in my other camaro"wheel hop" and i am pretty sure this isnt it i may be wrong thou, it just started doing this vibration ive had the same stuff the same tires everything and ive done some pretty big smokey burnouts, then lately it only did them one wheel then when i was doing a donut it started to do this, maybe i bent a lca or torque arm i dunno???
Old Nov 2, 2006 | 03:27 PM
on my other car i just put traction bars and what little wheel hop i had went away but im serious this isnt a small or medium size vibration this is like a bomb exploding and the doors almost gonna pop open lol. i wouldnt be suprised if my windows break
Old Nov 2, 2006 | 03:42 PM
BJM's Avatar
BJM
Wheel hop can be really bad. Does it drive normally otherwise? What about spinning the wheels in water, the same problem but greatly reduced? If so its probably wheel hop. Any amount of slop in the LCA bushings and wheel hop goes from annoying to ridiculous. A loose torque arm or bad transmission mount an contribute to it as well. As you tighten components up the hop frequency goes up and the jarring reduces. When its tight enough in all affected components, the wheels just spin rather than hop.
Old Nov 2, 2006 | 04:07 PM
yeagh i drives fine otherwise!! thats whats really weird, okay i just took the car out and had someone watch the rear end for the first time. and all to my dismay it was WHEELHOP!! ahh damnit, so it does it sometimes in drive and really really bad in reverse. so know that i know my rearend is okay!! YOU KNOW IT NEVER DID THIS UNTIL I PUT A NEW TRANS MOUNT IN MY CAR!! THIS MAKES SENSE THE OLD ONE HAD BEEN BROKEN IN TWO!, so whats the best way to fix this??? just lca arms and a new panhard bar?? anything else????
Old Nov 2, 2006 | 04:08 PM
oh yeah and when i go around a right hand turn and punch it only the right tire spins not both so i know my posi is kinda seeen better days so im gonna buy an auburn anyways,, "its for fun" lol
Old Nov 2, 2006 | 04:12 PM
BJM's Avatar
BJM
Panhard bar really won't affect it. The LCAs have the biggest effect. Are you saying that prior to the trans mount, it did not hop? Sounds odd that it does it now if that's true.
Old Nov 2, 2006 | 04:26 PM
Gary Z's Avatar
Wheelhop can also be caused by worn shocks or worn LCA bushings. My car with completely stock suspension had no wheelhop.
Old Nov 2, 2006 | 05:19 PM
yeagh before the mount no problem ,, so i dunno
Old Nov 2, 2006 | 06:42 PM
joecar's Avatar
New rear end bushes and shocks.
Old Nov 2, 2006 | 07:10 PM
jebcamaro's Avatar
I don`t wnat to sound like a jerk, but why are you doing all these burn outs? The object is to not spin out. If you are doing these on street tires, then your only burning your tires up and wasting your money. There is no need to heat up street tires, only drag tires.
Old Nov 3, 2006 | 10:51 AM
okay welll its not like i am going around burning out everywhere, how it all happened was i was racing and evo 8 and 99% of the time from a dead stop if i just punch it my car doesnt burn out for longer like 3 or 4 feet then just pure traction, but when i was racing a week or so ago my car all of a sudden just started to shake "wheel hop" all theseb other burnouts i have done since have been in the name of science!
dont trip speak your mind. i know i do when people do stupid ****. but yeah i have maybe done 2 or 3 intentional burnouts the whole time ive had the car. and at the track i dont stage i roll around the water box and just run. i get traction i dont need slicks..
luke
Old Nov 3, 2006 | 10:54 AM
but yeagh my friend has got bran new stock lca, i am goiing tommorrow to pick them up hopefully it fixes my problem if not i am thinking a new panhard bar. and shocks. but when i do shocks i wanna put really nice adjustable konis or qa1 or something like that,
Old Nov 3, 2006 | 11:07 AM
omcar's Avatar
Default get hotchkis lower control arms
wheel hop will be gone..other than that, an adjustable torque arm would be good as well.
Old Nov 3, 2006 | 11:16 AM
yeah if these stock units do not fix it im gonna have to spend a little money and get after market parts, i was reading in one of my catelogs on global west and they have a torque arm, but you have to drill into the car to install it!!! i dont want to drill into my 99 , maybe if it was my 74 camaro but not my new one Fu&# that! but yeagh there torque arm is adjustable, which is pretty sick!
Old Nov 3, 2006 | 11:30 AM
BJM's Avatar
BJM
If you are concerned about noise and/or problems with poly bushings you don't need them to solve your problem. Just check out this link for where I modified my stock arms. Look at the bushings photos, just make sure you order the full rubber ones. They are actually quite stiff despite what people think. the gapped ones are much softer. Moog replacements availabe at parts places are the same as the LE1 GM bushings everyone raves about. They are also quite cheap.
Old Nov 3, 2006 | 11:41 AM
nice work! did where did you get those bushings, from the dealership?? cause im going to pick some stock bran new arms up tommorow , maybe ill order some steel today to my shop weld those plates on take out the bushings and then send the arms down to get powder coated so they look nice! put those bushings in and hopefully they fix my problem, did you feel a difference after installing those,?
