5/8 studs
Old Nov 1, 2006 | 09:52 PM
1redta's Avatar
Default 5/8 studs
the rear end I currently have on my car (Moser 35 spline gun drilled star cut)has the moroso 5/8 studs, they are great for draglite type rims but stock type wheels you need acorn type lug nuts to locate the rims, is there a way I can switch them out to the regular 1/2 studs from 5/8? I don't want to have to buy new axles to mount up some regular rims that use the acorn type of lug nut Thanks Art
Old Nov 2, 2006 | 06:30 AM
Firechikn's Avatar
Take the axles to a machine shop and let them redrill new holes in the flange.
Old Nov 2, 2006 | 05:17 PM
8a8mfh's Avatar
Only problem is that they are star cut. They 5/8 holes need to be welded shut and redrilled. Thats going to run the price up if that can even be done.
Old Nov 3, 2006 | 09:21 AM
1redta's Avatar
Default re
damn street stars it is thanks guys
Old Nov 3, 2006 | 10:47 AM
SPEEDYws6's Avatar
I was in a bind once and had to put a set of stock wheels on my 5/8 studs, so I bought a set of 5/8 acorn style lugs out of the circle track section in jegs.
Old Nov 4, 2006 | 09:13 AM
1redta's Avatar
Default re
didn't even think about circle track studs good idea
