measurement for driveshaft?
Old Nov 7, 2006 | 10:33 PM
Trashed's Avatar
Default measurement for driveshaft?
hey guys im needing a measurement for a driveshaft to my car. it has a tci super streetfighter th-350 and a moser 9". any help would be great!
Old Nov 7, 2006 | 10:54 PM
GOaT Cheese's Avatar
You're really gonna trust one of these guys to give you driveshaft measurments? A driveshaft can be measured several different ways, I hope you are all on the same page.
Old Nov 7, 2006 | 11:09 PM
Trashed's Avatar
well what are the best ways to measure it then? if you dont mind me asking?
Old Nov 8, 2006 | 12:08 AM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
Load the axle as if it were sitting on the ground and measure from center of the u-joint on the pinion yoke to the seal on the transmission. Thats the usual measurement that any driveshaft manufacture will need to build one up.
Old Nov 8, 2006 | 07:15 PM
Trashed's Avatar
alright man thanks. have yall made one like this before?
Old Nov 8, 2006 | 08:38 PM
Trashed's Avatar
i measured the d.s. and i got 46.5 inches. does that seem right to yall
Old Nov 8, 2006 | 09:36 PM
Where did you measure it from? The tip of the yoke to the rear U-joint? Or from weld to weld? Or the total from both joint centerlines? Or form the rear joint centerline to the front U-joint strap? Or From the rear U-joint centerline the front yoke tip? And if you are comparing, make sure the other dude measures the exact same way.
Old Nov 8, 2006 | 10:22 PM
Trashed's Avatar
the centers of both yokes
Old Nov 10, 2006 | 04:12 AM
EPP's Avatar
EPP
Smile
http://www.exoticperformanceplus.com....html?item=827
There is a diagram in the above link that may help you out. Bob
