Help ASAP!!!!
Old Nov 11, 2006 | 04:44 AM
JeaneGrae's Avatar
Default Help ASAP!!!!
I had a shop change my rear end fluid recently. They added High Performance Valvoline 80w-90 GL-5 LS gear oil. It says it's specially formulated for limited slip, high horse/torque power applications. The mechanic said with this fluid I did not need the GM limited slip additive. I don't know how true this is, should i add it myself or will i be ok? I have the same Auburn High Perf Diff That was installed in the Firehawk and SS cars. Any suggetions?
Old Nov 12, 2006 | 12:17 AM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
If you are getting clutch chatter then add the additive. If it's quiet after it is warmed up then just leave it alone.
Old Nov 12, 2006 | 01:56 PM
JeaneGrae's Avatar
Default ......
What does clutch chatter sound like? Should i listen at a particular rpm range/speed, at idle, certain gear?
Old Nov 12, 2006 | 02:05 PM
2001NBMZ28's Avatar
Probably most noticeable at low speed when making a turn.
