Is this true?
Old Nov 11, 2006 | 08:41 PM
jp74's Avatar
Default Is this true?
I spoke to a summit racing rep today. I was going to order a 3 series carrier because I want to go from 2.73 to 3:23 or 3:42. he told me that Summit makes a 3.42 gear which is compatable with the 2 series. He explained that the gear set has thicker gears. I did the research on Summit racing website and it also stated it does fit. The part number is SUM-741014. Here is the link, it states Fits 3.08 and numerically lower carriers. Am I missing something?
http://store.summitracing.com/partde...5&autoview=sku
Old Nov 12, 2006 | 12:27 AM
GOaT Cheese's Avatar
No, you're good. There are several "conversion" gear sets out there. That way you do not need to change the entire gear case just to go up or down in ratios.
Old Nov 12, 2006 | 07:26 PM
jp74's Avatar
Thanks for the info goat cheese!!!
Old Nov 12, 2006 | 09:52 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
You know there are sponsor's to your right that carry the same if not better parts for your application. Just an observation.
