rear end
Old Nov 18, 2006 | 10:21 PM
stroked383z's Avatar
Default rear end
is it normal to have a small clunking noise coming from the rear end of the car at low speeds???
Old Nov 19, 2006 | 03:44 AM
ttt for sunday
Old Nov 19, 2006 | 07:32 AM
TX_SS's Avatar
yes itz normal if you have stock 10bolt.
Old Nov 19, 2006 | 10:14 AM
alamantia's Avatar
yup, even more noticable with an aluminum driveshaft
Old Nov 19, 2006 | 04:13 PM
blue01ta's Avatar
Just for fun make sure your lug nuts are tight.
Old Aug 8, 2007 | 11:23 AM
South's Avatar
It is worse if you slow the car down to about 35 kmph while in 4th?
Old Aug 8, 2007 | 11:28 AM
Jon5212's Avatar
That is not normal lol, I have a stock 10 bolt and it doesnt "clunk" when going slow or slowing down.
Old Aug 8, 2007 | 11:43 AM
South's Avatar
Mine was fine for ~65,000 km, but now I get a clunking noise from the rear.
Here are some details:
If I slowly come to a stop, out of gear, I hear/feel a clunking from the rear of the car
Dealer replaced fluid (and friction additive)...still clunks
Dealer replaced bearings, housing, and a few other parts (~$2100 under warranty)...still clunks
Clunks when the rear end is not under load (i.e. going down a hill with cruse control on)
If you leave the car in 4th as you slowly come to a stop, you will hear the clunking noise at around 40 km/h
If you are driving and the gear your are in is too high for you speed this will often result in a clunking noise
Any ideas?
Thanks,
Jason
Old Aug 8, 2007 | 11:53 AM
South's Avatar
The clunking noise can also be produced by repeatedly engaging and disengaging the gas pedal at a low RPM.
Old Aug 8, 2007 | 12:12 PM
Jon5212's Avatar
Check your Lower control arms... my cousin was having the same problem on his 99 SS, he has aftermarket bolton relocation brackets and they had come loose.
Old Aug 14, 2007 | 05:07 PM
SUCK MY SS's Avatar
make sure your torque armo bolts have not come loose.....my car would clunk everytime i hit the brakes or shifted gears...turnsout the torque arm bolts were only on finger tight....tightened them and the noise went away...
Old Aug 15, 2007 | 08:00 AM
South's Avatar
The dealer covered ~$2100 worth of work, under warranty, to resolve the clunking noise, which continued to get worse over time. When I got the car back it was still making the same noise, so I decided to tighten some of the bolts in the rear (i.e. lower control arm bolts etc.). The bolts were loose and tightening them resolved the issue for 4-5 days.
Im looking into getting the brackets welded in place now.
Thanks for your help!
Jason
