vibration at high speeds
Old Nov 23, 2006 | 11:41 AM
N2O-ARMD's Avatar
Default vibration at high speeds
I am having a vibration a high speeds I have changed the drive shaft and changed the pinion angle back to zero degrees. I'm not sure if its from the spone tourque arm just transfering it from the rear or not. I did't have it before I put the tourque arm on I had a BMR trans mounted one prior to the spone. The tourque has a rod end on it should i put the poly bushing on I'm not sure if it will make a difference due to design of their tourque arm. I also had the wheels and tires rebalanced I found that the wheels are running out in both directions but they balanced so I'm not sure what to do. Any ideas would be nice.
Old Nov 23, 2006 | 12:49 PM
98trans-am's Avatar
i actually just learned yesterday that an offbalanced drive shaft can also cause vibrations, i had never heard of such a thing before but check that out it wouldnt hurt. i guess some shops or even youre dealer might be able to do this.
