Strange 12 bolt is on the way!!
Old Nov 24, 2006 | 12:12 PM
thunderdan74's Avatar
Default Strange 12 bolt is on the way!!
I just ordered my 12 bolt from TBYRNE. I can't wait to see how those 4:10s feel!
BTW, Is it true you're not supposed to use synthetic fluid for an Eaton?
Old Nov 24, 2006 | 12:47 PM
MeentSS02's Avatar
Kleeborp the Moderator™
That's what I understand, and why I'm gonna run a non-syn in mine.
Old Nov 24, 2006 | 01:10 PM
ss1's Avatar
ss1
I called Strange on this last year. I was recommended 85w-140 non-synthetic.
Old Nov 24, 2006 | 01:12 PM
MeentSS02's Avatar
That's what weight I'm running too...as soon as Torco gets it to me
Old Nov 24, 2006 | 02:23 PM
westxwitesnake05's Avatar
youre gonna like the 4:10s
Old Nov 24, 2006 | 05:55 PM
98 SNAKE EATER's Avatar
I had stickers on mine that said to use 80w-90 NON-Synthetic and a bottle of additive:
However, I was advised by Jim Buschman @ Strange via email to use 85w-140 Non-Synthetic and 2 bottles of additive
But now I've got other problems (see my ABS sensor thread)
On a sidenote, make sure you check that the gears are correct BEFORE you accept the rear!!
I ordered mine with 4.11's and they came with 3.73's
I had already painted it and was ready to install....
Good thing I did a last minute check....
Rick
Aztek T/A WS7 & 70 RAM AIR IV T/A
Moderator @ LS2, FAST LS1, FUELSLUT,
The F-Body Hideout, LS1Turd & ChopperForums
Old Nov 24, 2006 | 06:39 PM
MeentSS02's Avatar
Rick
Because of you, that was the first thing I checked upon delivery. They at least got my gears right (numerically)...it remains to be seen whether or not they were set up correctly. And after a few stories of ABS problems like you (and skytower31), I'm glad I didn't go that route. Now to find the time to install my SJM ABS delete...
Old Nov 24, 2006 | 06:48 PM
little potato's Avatar
Ant of the Eatons with carbon clutches will hum during turns if you use a synthetic fluid. I found that out a few years ago the hard way. Or at least the pain in the *** way since I had to replace the clutch pack.
Rob
Old Nov 28, 2006 | 12:04 AM
I plan on checking as much of I can.
My friend just got a Moser12 bolt. It was ordered with a 1310 yoke but came with a 1350 on it. That 1310 managed to fit in 1350 yoke but I didn't like the way it fit. Luckly we had a spicer joint laying around the shop, otherwise I would not have suggested 'might as well give it a shot'
What kind of gains should I expect at the strip?
By Brett Foote | 2026-06-04 05:00:17
