Question on replacing factory gears
Old Nov 25, 2006 | 07:13 PM
Rxmfn7's Avatar
Default Question on replacing factory gears
A friend of mine has a '00 Formula firebird with an auto trans. Lately his rear end has been making alot of noise and it has been diagnosed that he needs new gears/bearings. He found a good deal on a set of low milage gears and axles, but without the housing. Is it possible to replace the axles/ pinion and ring gear assembly while still in the car, and if so, what all is involved in doing so? Is there a write up somewhere? Ive set up a few rear ends before, and although in different vehicles (IRS), it involved setting the backlash with a dial indicator and was a fairly involved process. He was told this swap is easy and could be done in the car in an hour or 2, and I just wanted to check into it more. Thanks guys...
