break 10-bolt while shifting?
Old Dec 1, 2006 | 06:42 PM
lomaximumta's Avatar
mines been decent so far...starting to get a lot more wheelhop than usual. Once I do my cam and have hopefully around 385+ rwhp I am going to be on borrowed time
Old Dec 1, 2006 | 06:58 PM
99zman's Avatar
lomaximumta or once you get your cam it will just break the tires loose easily and you wont have to worry? what gears do you have now?
Old Dec 1, 2006 | 07:12 PM
99zman's Avatar
Originally Posted by 98 SNAKE EATER
1-2 Shift
http://video.google.com/videoplay?do...30578368&hl=en
Motive 4.10's, ARP Studs and T/A cover
After I installed a new Strange 12-Bolt, I opened up the 10-Bolt and found a busted diff carrier with chewed up spiders
Surprisingly, everything else was still in tact, so I'm just gunna weld it up into a spool and use it as a spare
Rick
Aztek T/A WS7 & 70 RAM AIR IV T/A
Moderator @ LS2, FAST LS1, FUELSLUT,
The F-Body Hideout, LS1Turd & ChopperForums
snake eater what mods do you have done? and what tires were you running?
Old Dec 1, 2006 | 07:14 PM
RoastEmSS's Avatar
broke mine on the street on the 1-2 shift, when i hit second it blew
Old Dec 1, 2006 | 08:13 PM
stock 3:42's
Old Dec 7, 2006 | 05:15 PM
99zman's Avatar
what blew the carrier or the gears?
Old Dec 7, 2006 | 05:17 PM
99zman's Avatar
i know the good ole 10 bolt is weak but no one on here ever states how much they beat the **** out of it before it breaks?
Old Dec 8, 2006 | 11:38 PM
cws T/A's Avatar
Default 7.5 10bolt Lasted 6 months of street abuse
I shift mine pretty abusive and the rear broke today taking off 1/4 throttle 1-2 shift when I was leaving work. It had enough hehe I guess . Drove it 15 miles clunking making all kinds of racket, when I get home I go into reverse to harrass it more . clunk clank... ahh crap . Parked it .
Old Dec 9, 2006 | 12:44 AM
RoastEmSS's Avatar
snapped pretty much alkl the teeth off the ring and pinion. Only had 5 track passes on it to my knowledge and at the time only had headers. It lasted for 2 months with my mods i have now and it took more abuse than I thought it would
Old Dec 9, 2006 | 10:59 AM
98 SNAKE EATER's Avatar
At the time that video was shot:
K&N (w/LT1 style airbox)
Custom 3.5" exhaust built by Denny Tarcza or Mufflex
Spec Stage 3 X-Pad Clutch (w/Spec Steel Flywheel)
"288" Slave (w/Spec shim)
"277" Master (no drill mod)
Power Tower Shifter
Lou's Short Stick
Hurst "H" ****
Motive 4.10's
Ratech Solid Collar
ARP Studs
T/A Cover
Nitto NT450's up front (225/50/16)
Nitto NT555 R's out back (245/50/16)
I have since stepped up to a Strange 12-Bolt with 4.11's and MT DR's (255/50/16)
http://video.google.com/videoplay?do...55766185&hl=en
Old Dec 9, 2006 | 11:02 AM
MeentSS02's Avatar
Kleeborp the Moderator™
How's that Strange doing gear noise wise?
Old Dec 9, 2006 | 01:54 PM
  #32
99zman's Avatar
thanks for the info guys, 98 snake eater nice vid chirping 4th..
Old Dec 10, 2006 | 12:18 AM
  #33
miamifan3413's Avatar
Originally Posted by MeentSS02
Oh yeah? Well, I body slammed my 10-bolt, and it is still going strong
Good thing the 12-bolt is on emergency standby though...
I have 4.30's in my 10 bolt & beat it up pretty good....no probs as of yet
Old Dec 10, 2006 | 04:37 PM
  #34
It's pretty silent when accelerating, but whines a bit during decel....
Also, when coasting under light throttle, there's a hefty moaning at a certain sweet spot
I've grown used to it, but I've had dozens of people take a ride and ask "What's that noise?"
Oh yeah, it's clunky as hell when making tight turns, but I've got other problems as my ABS sensor recently got munched by the reluctor ring
Old Dec 10, 2006 | 04:39 PM
  #35
MeentSS02's Avatar
Nice...I'm almost dreading the install because I know there will be issues of some sort. Guess you gotta pay to play in this game...
Old Dec 10, 2006 | 06:12 PM
  #36
99zman's Avatar
im not sure which is worse, broken ring and pinion on a 10 bolt or leaking, gear niose, clunking or the huge hole in my pocket + all of those issues??
Old Dec 10, 2006 | 06:21 PM
  #37
BLKWS.6's Avatar
I broke the 8.8 in my GT (4.10's, welded tubes) cruising at 70mph on the freeway! Its mechanical, any number of things can kill em'
(I was driving along and int started whining faintly, then over 20 miles it grew LOUD and I pulled over. Found out the bolt in the back had backed out some and the ring/pinion were whining like mad, mechanic put a longer/better bolt in, locktight-red and it was fixed...not really BROKE, but....)
Old Dec 10, 2006 | 08:19 PM
  #38
my99transam's Avatar
Thumbs down
Mine broke when I went to pass someone. They tell me that the right rear tire flew up in the air. That's what I hear anyways. The last thing I remember is that I was in the passing lane. Three days later I woke up in the hospital. Guess we went for quite a ride. Will post pics of my poor baby asap!!!
Old Dec 10, 2006 | 08:30 PM
  #39
Has anyone had any kind of serious accident like I did when your rear became toasted?
Old Dec 10, 2006 | 08:58 PM
  #40
99zman's Avatar
sorry to hear that. i hope you are ok? what happened to your rear end? when did this all happen?
