break 10-bolt while shifting?
Old Nov 28, 2006 | 06:38 AM
partyhardoo69's Avatar
Default break 10-bolt while shifting?
Im going to a m6 and was wonder who here has broke their 10-bolt while shifting???
I have 3.42 gears and a TA cover with about 800 miles on it. I wont be running a tire, but am scared to shift too fast...
Old Nov 28, 2006 | 06:49 AM
02WS6Bird's Avatar
unless your a bad driver i really wouldnt worry about your rear too much. i would however concern myself w/ the tranny more so than the rear in that case
Old Nov 28, 2006 | 08:06 AM
Studytime's Avatar
I'd worry about the 10-bolt five times as much as I'd worry about the transmission. My car broke a ring and pinion on the 2-3 shift at the track on drag radials.
Ben T.
Old Nov 28, 2006 | 09:47 AM
BrandonDrecksage's Avatar
it seems most people break it on the 2-3 shift cause most cars at the speed have traction. its not like going into second where you will break loose a little bit, or ease up a little bit because you know that you spin. The 2nd-3rd is usually pretty hard of a shift, and the rear will hook, which could cause failure.
Old Nov 28, 2006 | 10:20 AM
keliente's Avatar
You can break it by just looking at it wrong.
Mine broke on the launch.
Old Nov 28, 2006 | 01:10 PM
Studytime's Avatar
Mine broke that way too.
Ben T.
Old Nov 28, 2006 | 01:12 PM
pontiac's Avatar
2000 rpm's, street tires, dumped and POP new rear time
Old Nov 28, 2006 | 01:46 PM
atleast you can look at the engine wrong and gain hp
i'm shocked mine hasn't gone yet, i knwo the posi is **** though.
Old Nov 28, 2006 | 02:18 PM
Regginator's Avatar
mines at the same point as yours, the posi doesnt work anymore and it makes some weird noises sometimes. Cant wait until i gotta fix this too
Old Nov 29, 2006 | 05:33 AM
EPP's Avatar
EPP
One guy on here said his 10 bolt broke backing it out of the garage... Bob
Old Nov 29, 2006 | 04:29 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Oh yeah? Well, I body slammed my 10-bolt, and it is still going strong
Good thing the 12-bolt is on emergency standby though...
Old Nov 29, 2006 | 04:38 PM
Revelation Z28's Avatar
spun the tires in reverse and wheelhopped the thing to death
Old Nov 29, 2006 | 05:40 PM
BriancWS6's Avatar
Broke mine on the 1-2 shift first of this Novemember. The spider gears were GONE!
Old Nov 29, 2006 | 05:55 PM
ls1_doc's Avatar
I broke mine in an auto on the 1-2 shift on e/t streets. I broke another one on launch on the same tires.
Old Nov 29, 2006 | 06:02 PM
LorcinLs1's Avatar
I can't complain about my 10 bolt. I did a gear swap and beat on it for 20,000 miles and then it broke. I feel lucky that it lasted as long as it did.
Old Nov 29, 2006 | 06:08 PM
98 SNAKE EATER's Avatar
1-2 Shift
http://video.google.com/videoplay?do...30578368&hl=en
Motive 4.10's, ARP Studs and T/A cover
After I installed a new Strange 12-Bolt, I opened up the 10-Bolt and found a busted diff carrier with chewed up spiders
Surprisingly, everything else was still in tact, so I'm just gunna weld it up into a spool and use it as a spare
Rick
Aztek T/A WS7 & 70 RAM AIR IV T/A
Moderator @ LS2, FAST LS1, FUELSLUT,
The F-Body Hideout, LS1Turd & ChopperForums
Old Nov 29, 2006 | 06:58 PM
thing just got fed up with you and went lol couldnt take it anymore.
Originally Posted by 98 SNAKE EATER
1-2 Shift
Rick
Old Dec 1, 2006 | 02:39 PM
tippmann243's Avatar
im not an f body guy, im into s-series but i have an m6 swap behind my 4.3
when i was still on the 5 speed i skattered my 3.08 7 5/8 rear end on the 1-2 shift. part of the pinion was sticking out of the housing. ill try nad find my pictures of it
Old Dec 1, 2006 | 02:42 PM
MeentSS02's Avatar
Dood...you broke the rear, and the front
Old Dec 1, 2006 | 03:00 PM
enjoy
