Difference between 3 & 4 series carriers??
Old Dec 7, 2006 | 12:51 PM
alamantia's Avatar
Default Difference between 3 & 4 series carriers??
What is the difference between a 3 series and a 4 series carrier, and dont say 1.
I know you cant interchange ring & pinion gears between a 2 series and a 3 series carrier but what about a 4 series, will 3 series ring & pinion gears fit a 4 series and visa versa?
Old Dec 7, 2006 | 02:43 PM
Ouija's Avatar
Simple answer:
The ring gears are a different thickness because the posi units are different depths.
Old Dec 7, 2006 | 03:03 PM
alamantia's Avatar
cool, so what series do I have in my 2002 Z28 with a torsen? Is it a 4 series?
I ask because I always hear the term 4 series associated with torsens, i had 4.10's installed on my torsen and when i ordered the gears my only two options were to order 4.10's for a 2 series carrier (3.08 and numericaly lower ratio) and 3 series carrier (3.23 and numericaly higher ratio) Ive always thought what you are saying, that its just a different ring gear thickness but if I have a 4 series carrier and 3 series gears installed, that makes me wonder what the difference is.
Old Dec 8, 2006 | 10:36 AM
Ouija's Avatar
I've never heard of a f-body with a series 4 carrier in it.
If your car has stock gears and posi then you have a Series 3 carrier with 3.42 gears.
All M6's came with 3.42 gears and a series 3 carrier since 1994.
Old Dec 8, 2006 | 11:10 AM
keliente's Avatar
4 series carriers are found in 12 bolts if I am not mistaken. For instance, when I went to order a new set of gears for my 12 bolt, I was asked if it came with a 3 series or 4 series carrier.
No f-body 10 bolts come with 4 series carriers.
Old Dec 8, 2006 | 11:21 AM
alamantia's Avatar
Ok so 4 series torsen style carriers are for 12 bolts, now i get it thanks
alamantia's Avatar
Good answer as well, your da man!
Old Dec 8, 2006 | 11:41 AM
94z28L's Avatar
might wanna edit that, She'll
Old Dec 8, 2006 | 11:52 AM
alamantia's Avatar
i know... i was just being a wise-***
