New 1LE mount and still problem(clunking)
Old Dec 12, 2006 | 05:26 PM
98camaroLS1M6's Avatar
Default New 1LE mount and still problem(clunking)
I have a clunk under hard shifting and replaced the trans mount with stock 1LE the old was indeed torn, this helped but there is still a clunk and when I accelerate the shifter will rise about a half inch but this seems normal. My torque arm is tight, I don't know what else could be moving to create this? Could it be a bad motor mount, it sounds like transmount/TA problem but I checked everything and it seems tight. Should I try a poly mount? Could it be output shaft play or Driveshaft or something? thanks.
Old Dec 16, 2006 | 09:46 AM
99blancoSS's Avatar
Motor mounts. I had movement up the wazoo. Replaced all mounts with poly and nothing budges anymore. Also went with a reclocation bracket/trans mount for the TA from UMI.
Old Dec 16, 2006 | 03:42 PM
RA4926's Avatar
the easier and cheaper solutions to motor mounts is to pull the trans mount out and fill the gap with subfloor glue or a shitty hardening caulk. i used caulk and it works great
Old Dec 16, 2006 | 04:53 PM
RPOWU8's Avatar
Exhaust hitting the floor on drivers side?
DJ
