TC or Gears?
Once you have 3.23 gears, swapping to 3.73 gears will net you even less of a gain. More like 2 tenths, whereas a ST3500 converter will drop ET more than 5-6 tenths. Racing from a roll, a car with a converter has a very strong advantage, even without gears.
Choose a modest converter (like a Super Yank 3500), get a good cooler, and you will be fine.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
What I would like to see is some folks post before and after 60ft, trap speed and ET results for vig2800/w 2.73s or similar verter that is not too loose with 2.73 so I could estimate if there is any significant gain after 60ft.
I started out with a baseline of 8.9 @ approx. 82 mph with a 2.73 ta along with lid, k&n, and I think cutout. 60ft was right around 2.10 flat with an occasional high 2.0. This was on radials but traction was little issue at the track so better tires would have helped little. These times were recored thoughout 2000.
I swapped out to a vig2800 and nittos. With no other changes I was able to run a first time out 8.3x@88 with a 2.0 60ft spinning half way down the track.
Over the next few months and with no moeny spent I was able to get this 8.3 down to a best of 8.03@ around 90. The improvement was due to change of air pressure and adjusting shift points. Got 60's down to the high 1.7 range.
This was all done at an elevaton of 2000ft and the da usually in the 2500-3000+ range.
So there you have it. The vhange to the vig improved the 60 by 3 about tenths but I picked up 9 tenths.....in an 1/8 mile. Also gained 7-8 mph. These are unusual gains but there are factual and many off this board witnessed them along with one of the mods here.
On a side note....... the 2.73 geared absolutely kicked butt in the 1/8 mile for my setup. I went through the traps in second and it was pulling great. Had I been running a 1/4 the times wouldn't have been as impressive due to the 2-3 shift would have occurred right after the 1/8 mile and it would lose some once this occured.
btw......i'm not a vig pimp. Just stating facts. I now run a tp4400 and couldn't be happier and wouuld reccommend it to anyone interested in racing n/a.
<small>[ August 10, 2002, 12:40 PM: Message edited by: Rooster ]</small>
fyi.....
the 2.73 vig2800 was also an absolute blast to drive on the street. Much more fun than my current tp4400/3.73.
We've got 24000 miles behind the 382 stroker on the PI convertor with no troubles at all. Dependability with the PI unit seems, from what I've read on various boards to be a bit better with PI but then that's also what I bought so ...
<small>[ August 11, 2002, 08:00 PM: Message edited by: P&DZs ]</small>
