Can I put factory 3 channel ABS into Strange 12 bolt?
Old 12-29-2006 | 09:46 PM
drain89's Avatar
Default Can I put factory 3 channel ABS into Strange 12 bolt?
I have a Strange 12 Bolt laying around that I bought for my 3rd gen Camaro so it doesn't have the 3 channel ABS reluctor ring or sensor in it. It does have the hole with a plug in it for the sensor. Now that I bought the WS6 I would rather us the rear in it. I know that it is 3" narrower than my stock rear...that's not a problem. The rear has a detroit true trac in it. Is there any way I can order a factory ring and sensor and fit them to it?
Strange wants 65 for the sensor and I heard it is not OEM and seen the posts where folks had problems with it.
They want $150 for the reluctor ring and I have to send my true trac in to be machined for it and tack welded on. They will not sell me just the ring so I can have it installed myself. I know a first class machinist and one of the finest welders you'd ever meet, both of which I trust alot more than anyone at Strange.
What do you guys recommend?
Thanks.
Old 01-02-2007 | 01:15 AM
drain89's Avatar
Somebody?
