Are motive gears good?
Old 01-08-2007, 09:15 PM
BitViper's Avatar
Originally Posted by alamantia
I know they make um for the 10 bolt, but thats only 7.5" is that what you are reffering to?
Yeah I think so..the 10 bolt is teh stock M6 size is it not?
Or is my head up may *** again!
Old 01-10-2007, 12:26 AM
TDP
TDP's Avatar
Originally Posted by StreetLethal01
I have the Motive 3.90s bought from the WS6store PN MTG-G875390 and should have them installed soon. I'm going from 3.42s. I've also heard that Motive has less whine so that helped with my decission.
I've never heard of 3.90's for a 7.5" 10-bolt. I've installed Motive 3.90s in C5/C6 Vettes, Mustangs, 12-bolt & 9 inch, but that is it. If they do make them for a 7.5, that would be really nice!
Do you have a link?
Old 01-10-2007, 09:41 AM
14 Second Truck Club
mzoomora's Avatar
They are out there, fairly new. They came out about a year ago or so.
Old 01-11-2007, 12:41 PM
99zman's Avatar
i just ordered my motive 4:10's from texas speed along with a ta gridle, stud kit, and complete install kit. they said the only motive gears the sell are in the blue and black box. i called motive and they said i will not have any problems with these gears the only difference he said is that they performance gears are tripple lapped, some coating to make them a little quiter. but he did reccomend a solid pinion spacer. so i guess i have to order that now too? and he said that break in is 750 miles
Old 01-12-2007, 08:12 AM
TDP
TDP's Avatar
I just picked up the new Motive catalog, and it explains the difference. The orange box Motive performance gears are made of a harder, higher quality 8620 steel, where the blue box Motives are not.
Also, it DOES have a listing for the 3.90 ratio
Don't worry about the solid pinion spacer. However, I recommend a GM crush sleeve, NOT the one in the kit. The one in the kit crushes way easier than the GM one. It seems to be that if it takes more effort to crush, that it would be more solid.
Old 01-12-2007, 02:00 PM
99zman's Avatar
well what should i do with the gears then? i bought them as their ring and pinion package? i only want to do this once? i already ordered a solid pinion spacer .why wouldn't you want to use that? that's as solid as your gonna get.
Old 01-12-2007, 04:51 PM
99zman's Avatar
i called texas speed they are going to drop ship some motive performance gears to me and when i get mine in all i have to do is send the black and blue motives back to them. what a great place texas speed is.. i'm very pleased so far with them. great prices and customer service to boot.
Old 01-12-2007, 04:59 PM
SMOKKINU's Avatar
Originally Posted by therobman
yea mine are in a yellow and orange box they are motive proformace gears i baught them from ws6store.com i really think they guy didint know what he was talking about so i deff plan on bringing it somewhere else thanls
hopefully, you mean to the scrap yard, along with your 10 bolt, and straight home to order a 12 bolt from strange?
Old 01-12-2007, 05:09 PM
Ls1Bait's Avatar
I run motive gears and an Auburn posi unit, and pull 1.7x 60 ft. all the time.
Old 01-12-2007, 06:45 PM
mzoomora's Avatar
The material (8620) is the same for all the motive gear non-pro gear stuff, but the performance stuff is "cleaner". Either will be fine as long as they are set up properly. The performance stuff is easier to set up though and are less prone to noise.
Although we didnt get a lot of the blue box gears back either.
Old 01-12-2007, 06:50 PM
98camaroLS1M6's Avatar
motive gears are the quietest gears you can get on a budget, my buddy has them in his 10bolt and loves them.
Old 01-12-2007, 07:07 PM
  #32
99zman's Avatar
thanks for the info that makes me feel a lot better. im getting the performance gears anyway. mzoomora, do you or did you work for them or something? thanks again
Old 01-12-2007, 08:48 PM
  #33
mzoomora's Avatar
I worked for the full time for about 6 years, and part time after I joined the fire department for another 6 until recently. Could probably go back but I got a better side job. It was a great place to work for though, and they do make a great product. Most people dont realize how many other gear "brands" are actually just reboxed Motive stuff. Cant tell you who, but the point is there stuff is proven and everywhere. Has been used in NASCAR, ARCA, NHRA, IHRA, NMRA, on and on.
Old 01-13-2007, 01:26 PM
  #34
99zman's Avatar
thanks mzoomora. so the 750 mile break in thing is true then? i hear alot of people say 500 miles, what would you say? 750 miles is a long time not to get on the gas and try those puppies out????????
Old 01-13-2007, 01:28 PM
  #35
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
i baught these gears and the machanic said they were garbage and would break easly is this true i herd it was a good gear btw they are motive proformace 3.73 gears for my a4
Find a new mechanic. I have Motive 3.73's in my A4-equipped 'bird, and they're great.
Old 01-13-2007, 01:43 PM
  #36
mzoomora's Avatar
Get a few heat cycles in them and allow them to cool without any extended highway driving. New bearings and gears generate a lot of heat, that is why you cycle them. I have done 3 cycles (drive 15-20 minutes of stop and go or slow cruise, then cool for a couple of hours) and taken them to the track, but you should probably do at least a couple of hundred miles. For a tow vehicle or heavy vehicle the break in is crucial.
Old 01-13-2007, 01:51 PM
  #37
99zman's Avatar
thanks alot, i have 2 more questions. first what weight oil would you reccomend the 75/90 or the 85/140 non synthetic what are the advantages of both weight oils. second is a solid pinion spacer worth it to install? thanks again for the help.
Old 01-13-2007, 02:55 PM
  #38
mzoomora's Avatar
Yes on the solid spacer, helps a lot with deflection. As far as weight of lube, depends on climate and conditions. The heavier oil is good for high temps the lighter stuff is good for cold. I usually run lighter weight lube with limited slips myself, but it is best to go with what the diff manufacturer says (auburn, torsen etc.)
Old 01-13-2007, 03:00 PM
  #39
BriancWS6's Avatar
I have had no problems with them in my car.
Old 01-15-2007, 01:16 PM
  #40
mach2004's Avatar
Good quality gear, mine nearly always have a whine on decell. Other that that they are great.
Quick Reply: Are motive gears good?
