New Moser 9 leaking
Old Jan 6, 2007 | 07:27 PM
caddobass's Avatar
Default New Moser 9 leaking
New moser 9" with complete aluminum center section looks to be leaking from pinion yoke seal, has anyone else had this? I ordered the complete center section hoping not to have these issues.
Old Jan 6, 2007 | 07:47 PM
getusum's Avatar
Mine has leaked since day one....Had it only 2 months....
Old Jan 6, 2007 | 08:13 PM
94Z28Joe's Avatar
mine has done the same thing also leaks from the axle seals. that's what I get for using ford parts.
Old Jan 6, 2007 | 08:39 PM
csmc711's Avatar
are these all aluminum centers that are leaking? Axle seals leaking from too small a breather hole maybe? Just a thought.
Old Jan 7, 2007 | 08:34 AM
EPP's Avatar
EPP
I haven't noticed a problem at my shop with them leaking. The first thing to do is to make sure you didn't overfill it. Second is to make sure the vent line is not obstructed. Bob
Old Jan 7, 2007 | 09:33 AM
csmc711's Avatar
I must have had 9" on my mind in my sleep because when I woke up, thats what I was thinking, over fill some how, lol.
Now, just need to figure out what that vibration is about. Bob, is there really a 1" offset like was mentioned? I am so ready to order a rear, but, that vibration thing has me scared.
Old Jan 7, 2007 | 09:40 AM
94Z28Joe's Avatar
It's not over filled and the vent tube is not clogged or kinked. Leak is ok with me a just want the vibration gone. moved the rear towards the drivers side about a half inch and it still vibrates need to move it that way some more the drive shaft still doesn't look straight.
SPRAYED 01's Avatar
Ive had 3 9inchs, all brand new center sections in my f-body. All have leaked from the pinion from day one. Ive had the pinion seal replaced twice now and still leaking. Im just going to live with it. Every oil change i spray it down and it makes me feel better. For some reason i keep tricking myself into thinking that will fix it.
csmc711, ive always had a vibration also, what 1" offset are you refering to.
Old Jan 7, 2007 | 12:00 PM
RW99's Avatar
I also have a leak with my new Moser 9". Assuming that I check the fluid level often and ensure that I never go low... just how dangerous is a small, slow leak? What if it's also apparent at the third member?
Old Jan 7, 2007 | 11:43 PM
v8juice's Avatar
slow leak here since day one,when parked no leak,when driving it leaks
Old Jan 8, 2007 | 04:42 AM
EPP's Avatar
EPP
Question
The axle on the passenger side is shorter than the driver side axle. This should not cause a vibration, as it is well within what the U joints can handle. Bob
Old Jan 8, 2007 | 11:17 AM
caddobass's Avatar
Talked with moser this morning and they said the same check fill level and vent tube. I called the shop to tell them. They said when they put it up on the lift to do the torque arm they saw the leak and changed the pinion yoke seal then. They also said the pinion yoke shaft looked like it had been sand blasted around the seal area, now we know this should not be looking this way. They tried to smooth it out a little but still leaking. Fill level and vent tube correct.
Old Jan 8, 2007 | 03:18 PM
RW99's Avatar
Can anyone show a pic and identify the vent tube? Thanks...
Old Jan 8, 2007 | 06:31 PM
csmc711's Avatar
I dont he size of it, but, I wonder if it is posible that it is too small, if that indeed is the problem?
Old Jan 8, 2007 | 07:01 PM
hissin'98's Avatar
Mine leaks like a biotch from the vent in the front towards the top by the yoke but not too much from the vent tube on the axle tube. The oil was going in so slow that it started to just barely drip and I checked it to confirm it wasn't over filled. It just blows out the vent.
Old Jan 8, 2007 | 09:11 PM
B.Buster's Avatar
I had a 9 inch that seemed to leak from the pinion seal. Turns out it leaked through the yoke and out around the nut. Removed nut and cleaned with brake cleaner. Used sealer on nut and reinstalled.
Old Jan 8, 2007 | 10:41 PM
SSwanner's Avatar
mine does not leak at all fromt he pinion seal. it does leak around the center/housing ........damn advanced auto silicone
Old Jan 8, 2007 | 10:47 PM
MeentSS02's Avatar
Kleeborp the Moderator™
What is the correct fill capacity for the 9" rears? Just curious...
Old Jan 9, 2007 | 12:32 PM
csmc711's Avatar
Any one willing to try some seal swell stuff, lol? Either should fix the leak or not. Shouldny hurt anything but the seal and that is an easy swap. Wow, blows out the vent tube??? What brand lube are you useing? Maybe it is foaming up too much? Also would depend on where it was located too. I am asuming axle tube but thats just a guess.
Old Jan 10, 2007 | 11:15 PM
HAMRHEAD's Avatar
All that damn money it shouldn't leak!
