LOTS of fluid
Old Jan 8, 2007 | 05:24 PM
Black02Bird's Avatar
Question LOTS of fluid
Ok, whats it mean if i changed my rear axle oil and wound up using over a gallon before it ran out? and yes before you ask the car was level... are the inner seals bad?
Old Jan 10, 2007 | 04:56 PM
BitViper's Avatar
I over fillied mine but I only used 3 pints....Im sure it would have held one more pint..did you use teh correct filling hole or did you do what I did and used the "fill" port on the cover
Old Jan 10, 2007 | 05:13 PM
2001NBMZ28's Avatar
Should only be about 2 quarts - use the factory fill hole.
