4.10 gears = lower MPH????
Another thing i've noticed is that I woould previously get around 180-190 miles per tank and since the upgrade, I'm getting 210-220 per tank.
Do higher gears really lower your top speed, or is it just me?
the same mileage. Hope this helped!
the same mileage. Hope this helped!Thanks man!
as far as speedo, hopefully, you have a tune on the car, take it to who tuned it, hopefully with LS1Edit, and get them to enter in your 4.10's and reset the PCM for those gears, takes maybe 5 minutes. a tune with LS1Edit should be a 1 time fee of around $450-$500 and tuning for life. meaning when you mod the car later, you can come back and they'll tune it for free...since you already paid your dues.
Example, lets say he is cruising 88mph on his gauge, he is really only doing 60mph, so in 1 hour, he drove 60 Real Miles while his car is showing 88miles.
On my car, I lost a lot of mileage with the 4.10's due to me only having a T5 with a .74 5th gear. I'd be cruising at 3500rpm on the highway. With my 3.42's now I am at 2400rpm.
it took some getting used to the 3.42's since I would almost stall the car out when I would take off.
Try pulling it till the rev limiter , unless yours is 7,000 than I advise you dont .
My rev limiter is set to 9800rpm.
