410's in a 2000 SS A4
The reason why I say this is due to the fact that is this a street car, strip car only or a combo DD. There are quite a few people with big displacement th400 cars running 4.10 on motor with n20 but even with the extra rpms allowed due to better valve trains they are running out of gear. The same will apply to a4 cars since your not supposed to go into OD in the 1/4.
For my m6 some have recommended 4.30's in the rear but I like to drive my car, ill go to the track but thats like 3-7 times out of the year, the rest is cruising. So you gotta match your gearing to the combo.
Actually gearing and stall and the last things that should be done, or at least the modder should know his intended combo before gearing/stalling the car up, is to ensure proper matching and saving $$$.
For example, he is talking future project of a 427, which is serious bucks, so most likely it will be a 402/408 motor. The desired stall is going vary, every combo is going to demand a different stall speed.
If he wanted a garden variety stall converter that will work well with a stock block, mild cam, he would be 3000-4000 stall. But that stall in a 427/408/402/383 car is going to react differently, at that point he may not even have a 4l60e in the car, it maybe a th350/400. God knows once the tq management is removed all 4L60e's are suspect.
I have read to many stories where they never put enough or the cam mild cam in the car worked well with the mild stall but the ms4 now in the car really needs a loose converter. Thats just extra time and extra money that has to be spent.
Ive built my LT1 car up to the point where many of my future paychecks have already been called for so if I can pass along some advice I will.
But like you said when you buy a stall you should factor in a future cam, which unfortunately, not everyone does it.
do some more research. i've seen a few stock internal ls1's on 26" tires not do any better with a 4.10 vs. a 3.73.
if you plan on putting a large cam in the motor then i say go 4.10's... but if you're planning on staying stock internal for a while, i wouldn't waste the gas money for minimal (if any) gains.
