which is stronger
Old Jan 18, 2007 | 09:23 AM
gforcejunkie's Avatar
Default which is stronger
is a s60 or a 9 inch stronger. and which one is more efficient.
Old Jan 18, 2007 | 10:44 PM
t t t
Old Jan 19, 2007 | 01:11 AM
chicane's Avatar
The 60 is more efficient.
Which is stronger ?? Now there is a good question. Id like to say the 9" due to it being a 3rd member design housing and not rear loaded like the 12b, 60 and others. You can put 40 spline axles in either one of them and they have been used in equal high horsepower applications with good results all around.
But which is stronger ?? That is a damn good question... Ill say its a draw.
Old Jan 19, 2007 | 02:31 AM
i was thinking the 9 inch would have been more efficient seeing how its smaller gear
Old Jan 20, 2007 | 01:28 PM
chicane's Avatar
The 9" pinion centerline is much lower than that of a rear loaded differential and many other third member designs.
Old Jan 20, 2007 | 03:30 PM
BlackScreaminMachine's Avatar
Internet Mechanic
The question is what kind of power are you expecting to make to even consider the question.
Old Jan 21, 2007 | 02:52 AM
well whatever it takes to get in the 9's
Old Jan 21, 2007 | 04:10 AM
EPP's Avatar
EPP
A Moser 9 inch will work just fine for you, and it is shipped just two days after the order is received. Bob
