Have a wierd problem and nobody knows the solution...Need Help!!
What is the problem with my car what would make it do this?
air/fuel map (air reversion can really mess
with the O2 sensor fidelity). Maybe you got
tuned this way? Wasn't clear. The extended
exhaust eliminates this and the mixture needs
to be remapped. You might try to force a
relearn, or you might try driving around,
teasing the trouble point and see if it learns
its way out of it.
Sure sounds like it's not delivering fuel at
low vacuum / high load.
