How to get axles out???
Old Aug 24, 2002 | 02:43 AM
theblur98ss's Avatar
Default How to get axles out???
How do the axles come out of the stock 10 bolt. I undid the backing plate and they come out a half inch maybe but won't come out any more. I need to get them out so I can use the plates on my 12 bolt.
Old Aug 24, 2002 | 04:28 AM
Damian's Avatar
LSX Mechanic
Default Re: How to get axles out???
You have to pop the cover on the rear end and pull out the c-clips on the end of each axle.
Old Aug 24, 2002 | 09:42 AM
DriveATransAm's Avatar
you have to undo everything off the ends of the axles...then you need to be able to push them in. of course make sure you have that plate in the middle removed first. once you push the axles in the c-clips will drop off and you can pull the axles out <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Aug 24, 2002 | 10:41 AM
DERTY's Avatar
The Bull
The exciter ring sensors need to come out. Small 10mm bolt holds it on. Simply slide it back and push the axles. You'll hear the c-clips drop off.
