Ready to order12-bolt, options???
Car 99 SS M6 ABS, traction control.
This is what I was going to order:
Moser 12 bolt with Eaton 33 spline posi, 3.73,
TA girdle option,
1350 Yoke,
4 channel ABS setup,
exciter rings installed,
I haven't decided yet on if I want the c-clips or the bearings pressed on the axles. What about the universal joint, is there a particular part number for the 1350 yoke? Any suggestions greatly appreciated.
Is this all the info. I need to order? What other pieces will I need to ease with the istallation?
Thanks in advance,
Kevin
You'll also need a new u-joint for your drive shaft. There is a 3R to 1350 cross over that you can get from Napa. That u-joint has equal widths on both sides, but the caps are different diameters. Make sure that you get the right ones. On my driveshaft I had to get a Spicer u-joint instead that had 1.0625" caps instead of the 1.125" caps found on the 3R. E-mail me if you need the part numbers for both u-joints.
