How to install a Posi unit and gears???
Thankyou
i would still like to hear some advice on any of the probs that I might face. Thanks
From there, just take your time. After you get your pinion depth right (with the right amount of shims) your only half way there. You will need to get the carrier adjusted so you have the correct amount of backlash. When shimming the bearings (on the carrier) they should NOT spin freely. You need to shim it so there is some resistance. This will loosen up as the rear end is "breaking in"
Next is the tooth contact using the grease marking compound. You should find pics of this some where. When checking it, use a pray bar on the carrier (to give it some resistance) and spin the pinion. Not using the pray bar will give you a false reading. If the pattern is not correct, than you need to go back and change some shims. What shims depends on the pattern you get.
Hope this helps - Ron
good luck with that
