Need HELP Diagnosing sound!!!
Old Aug 26, 2002 | 08:06 PM
MOBE's Avatar
Default Need HELP Diagnosing sound!!!
Not sure where to post this, but here it is...
A little over a month ago I had some exhaust work done to my t/a. I had a bullet muffler welded into the i-pipe, then a cut-out, and on back through a Hooker catback (also have hooker lts and ory). After a month or so of driving it with the cut-out open (sounds freakin awesome <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> ), I seem to have developed a "new" noise.
I first noticed it about a week ago. A "chirpy" metal on metal kind of sound. It wasn't very noticeable at first, only when I shifted and the exhaust note reached a certain pitch would it squeek and chirp. Now it seems to have gotten worse <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> , and found a much wider exhaust pitch range to squeek at me. I checked all of the exhaust piping and didn't come up with anything there, so I thought it might be suspension related, but when I drive over a bump or rough spot in the road it doesn't seem to do it.
BTW... When sitting in the driver seat, the chirping seems to be coming from the right rear of the car. But I could be wrong.
...ant ideas are appreciated! Thanks
Brian <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" />
Old Aug 26, 2002 | 08:29 PM
99WhiteSS's Avatar
Default Re: Need HELP Diagnosing sound!!!
Is your muffler a dual out? If so make sure that one of the pipes out to one side of the car (probably the passenger side) is not rubbing up against the muffler's main inlet pipe from the engine. These pipes can be very close together where they join to the muffler and cause some metallic chirping/squeeking when the car squats (like during hard shifts). Good luck with it. Those noise gremlins suck!
-kjb
Old Aug 26, 2002 | 08:52 PM
MOBE's Avatar
I don't think its that, because I had the two welded together. ...then again, maybe theweld broke?
THX!
Old Aug 27, 2002 | 06:34 PM
MOBE's Avatar
ttt
