~~~~Help me, axle stuck in diff~~~~
Old Aug 26, 2002 | 08:18 PM
99taws6's Avatar
Default ~~~~Help me, axle stuck in diff~~~~
Well first of all a little about what happened. I went to the track on Saturday to get some wheel time in. I had a so so day. Best on Bottle was a 12.55@116 and the best on motor was a 12.86@111 . I made about 10 runs total. I borrowed a set of Nittos from a friend. I have been through two sets of Nittos on my own, but these were 315 35 17's.
I did my normal 4-6 second burnout and then staged. I launch at 3k off the spray. I never spray in first gear. My best 60 of the day was a 1.9. On my second to last run I felt a clunk and a shake when I turned onto the return road. Upon inspection I found that my panhard rod was loose. I tightened it and went to make another run.. When this run was done, it was making loud noises from the rear. I drove the car home. On the way home it was surging like something was slipping in the rear as well as clunking bad when going up hill.
Well today I pulled the cover to find my rear filled with metal shavings and fragments of my Torsen Diff. I started to disassemble it when I ran into this problem:
1. Removed C-clip retainer, rear brakes.
2. Pushed passenger side axle in and C-clip dropped and axle came right out.
3. Tried the same with the driver side and had no such luck. It seems that the gear is stuck on the end of the axle. I can wiggle the C-clip, but it will not fall out. We tried to wedge the gear so that we could knock the axle in a little further. No luck.
I am thinking tomorrow I will get a bigger hammer to hit the axle in with and wedge something against the gear to hold it still.
Any ideas on how in the heck I can get this axle out?
Old Aug 26, 2002 | 09:15 PM
wrencher's Avatar
wrencher
Default Re: ~~~~Help me, axle stuck in diff~~~~
Have a friend tap axle in while you tap side gear out towards him. Hopefully it will move enuf' to drop c-clip then your probably gonna have to tap axle all the way out. GOOD LUCK!! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Aug 26, 2002 | 09:17 PM
99ZEOD's Avatar
Hey George, I'll give you a big TTT.
Old Aug 26, 2002 | 09:19 PM
99ZEOD's Avatar
We tried that with no luck. And we were pounding that thing. <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" />
Old Aug 27, 2002 | 09:49 AM
99taws6's Avatar
ttt
Old Aug 27, 2002 | 10:41 AM
XtraCajunSS's Avatar
Do you have ASR? If so, I had to remove the ABS sensor to allow the axle to be pushed in all the way. It was only probably a 32nd difference but it was all it took...
Shane
Old Aug 27, 2002 | 09:19 PM
wrencher's Avatar
wrencher
Got a decent air hammer & torch? <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Old Aug 27, 2002 | 10:39 PM
99taws6's Avatar
axle came out... Turned out I twisted the axle as well... It just took a little persuasion from a Large Hammer.... Now I need to by an axle and a Diff... <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Aug 27, 2002 | 10:42 PM
I have a whole stock rear with 3.42's and ASR for sale... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Shane
