growling a slight squeaking when turning right?
Okay, WTF, lol???? If I make a right turn, it sounds like my axle bearing is totaly worn or something, but, both sides are brand spanking NEW with new seals! If I make a turn to the left, it is quiet as a mouse!?!? It does not matter if I am crawling in a parking lot turning circles or on the highway taking an exit/entrence ramp. I also get what sounds like a ever so lightly metal squeaking/scraping sound, like you hear on them low brake sensor tabs, but, them too are brand spanky new.
During the right hand turn growling, and boy does she growel, if I do give it the slightest bit of gas, it goes away (just found this out going to my girlfriends tonight).
I replaced my ring/pinion bearings and carrier bearings too?
Any ideas to this phenominon?
Thanks all....
Well, i have some 3:73 unknowns I just threw in there (yea, I now, I know) for now. Absolutly NO whining on driving and just a little on stright decel. I would have thought I would have whine on decel no matter turning left or right, which I do, but, it is ONLY turning right and off the gas coasting she begins to REALLY growel????
I know my pinion bearing is a little loose, so, geometricaly speaking, does turning right make the pass rear tire/axle move inward, which would put preassure on the driveshaft and shifting the pinion into the ring gear more? Turning left would pull it away???? Thats the only thing I can think of, lol.
