new gears
Old Feb 1, 2007 | 02:40 PM
One Of Many's Avatar
Default new gears am I missing something
I just got my 3:42's and I will be getting rid of my 2:73 I was just wanting to know what I should expect in the time slip area. With 2:73 I was going at a 13.5x
Old Feb 1, 2007 | 03:01 PM
alamantia's Avatar
1/2 a sec with bolt ons id imagine, are you reusing the carrier? Did you get 3.73's for a 2 series?
Old Feb 1, 2007 | 05:24 PM
Sorry not sure what you mean by "carrier" or "Did you get 3.73's for a 2 series?" This is what I bought http://cgi.ebay.com/ebaymotors/Motiv...spagenameZWDVW Will I need something else?
Old Feb 1, 2007 | 06:27 PM
Can someone explain this to me?
Old Feb 1, 2007 | 06:42 PM
bene's Avatar
Trunion King
Get a 3 series posi like Auburn, eaton or Zexel. The one you have now w/ your 2.73 will not work. 2.73 stock rear is 2 series carrier while 3.42 is a 3 series.
RegalX's Avatar
those are for a series 3 carrier, you have a series 2 carrier, so your going to need a ring gear spacer and longer ring gear bolts, I bought one off ebay it was pretty nice, I just took a brake lathe stone to make sure it was totally flat on both sides before i installed it
Old Feb 1, 2007 | 08:03 PM
5_02ls1's Avatar
Default spacer
most mail order speed shops summit,jegs ect carry these spacers.the difference is the offset of the carrier to make up for the thickness of the gear.have the gears been shipped out if not ask the seller if they have a set for the 32carrier.i went from 273s to 373s .let me tell you its like the difference from daylight to dark.
Old Feb 1, 2007 | 08:08 PM
bene's Avatar
Trunion King
I was told, it is not recommended to put a ring gear spacer to adapt 2 series carrier w/ 3 series gear. Why? It will be a weak point of your rear. 10 bolt is known to be weak already, making it weaker is worse.
Old Feb 1, 2007 | 08:13 PM
5_02ls1's Avatar
thats the dumbest thing ive heard wow is a steel spacer gonna make it weaker.
Old Feb 1, 2007 | 08:15 PM
Is this what I need http://www.jegs.com/webapp/wcs/stores/servlet/productitem_10001_10002_759333_-1_232602
Is there any cheaper?
Old Feb 1, 2007 | 08:22 PM
bene's Avatar
Trunion King
Link is not working^^^
Old Feb 1, 2007 | 08:24 PM
bene's Avatar
Trunion King
Its not the steel that is going to make it weaker... its putting the ring gear spacer. If you're going to do something, do it right... Just swap it w/ either both 2 series carrier posi and gear or 3 series posi and gear.
Old Feb 1, 2007 | 08:38 PM
RegalX's Avatar
i've run a ring gear spacer in mine for the last 3 years and 50+ passes down the track, My car doesnt make much power and its an auto, but its worked fine for me, my car only pulls 1.9 short times tho
Old Feb 1, 2007 | 11:07 PM
2002tone's Avatar
thats what i was talking about kyle with the series 2 carrier
Old Feb 1, 2007 | 11:25 PM
Since I have already bought these gears and have them in hand what will I need to finish the series 3 carrer?
Old Feb 2, 2007 | 07:21 AM
alamantia's Avatar
Return the gears and get the correct ones
Old Feb 4, 2007 | 12:00 PM
I bought them on e bay so I wont be able to do that. Since I am going to go ahead and switch to a 3 ser. is there a stronger or better posi unit I should look at?
Are these what I need?
ebay
ebay
Old Feb 4, 2007 | 02:25 PM
How do you know what car has a 2 ser and what car has a 3 ser?
