3.23 or 3.42
Old Feb 6, 2007 | 10:19 AM
98NATA's Avatar
Default 3.23 or 3.42
My car has the GU5 code and i thought it was completely stock when i bought it, but i think i may have 3.42's: at 55mph~1750rpm, 60~1900, and 65~2100. I did the gear calculator and it seems closer to 3.42's. Can anyone with either gears help me out to see which sounds right. The best tank i've gotten has been about 20mpg, which seemed low and it just seems like it tachs high going down the highway, i just figured a M6 rear may have been swapped in, any help would be appreciated thanks.
Old Feb 6, 2007 | 11:48 AM
CodeRed2000SS's Avatar
well u are right, a m6 only came with 3.42's, but on the other hand a 3.23 isnt that much different than a 3.42. some of the time the numbers on a calc dont match the actual # the gear is. just my 2 cents
Old Feb 6, 2007 | 11:57 AM
alamantia's Avatar
you have 3.23's
if anything count the rotations of the drive shaft as you spin teh rear tire around once
Old Feb 6, 2007 | 06:43 PM
98NATA's Avatar
Just out of curiousity how many times should the driveshaft rotate with 3.23's? This mileage sucks and only driving it for highway runs i wish i would have just got a six speed
Old Feb 6, 2007 | 08:35 PM
HossZ28's Avatar
It should rotate 3.23 times with one tire rotation.
Old Feb 6, 2007 | 10:46 PM
jimmyblue's Avatar
Moderator
2500RPM at 80MPH locked up with 3.42s and 285/40R17s
Old Feb 7, 2007 | 09:22 AM
98NATA's Avatar
I'll check it out, thanks guys
