Royal Purple Causing Rear-End Failure!
I hear ya, but everyone's science doesn't seem to agree. Every manufacturer of automotive lubricants has tests to prove how superior their product is. I never know who to believe. I've been a service advisor for 10 years and have only seen differential and transfer case failures due to lack of service, no fluid, or severe abuse. Maybe in the racing world, you have other evidence- after servicing seeing the fluid coming out and looking or smelling distinctly different than others, monitoring rear end temps during high speed racing, etc. Our shop techs all run the 75/140 synthetic BG fluids in every car and haven't seen a single issue. Of course, these are not racing applications so maybe it's not a good comparison. I did bring up that mine calls for 75/90, but they are convinced the 75/140 BG will work fine.
Originally Posted by Redlinez
Ask 3 more people and see what you get. I only wish you had left the Ammsoil in it. As for the weight, I'd like to see proof on that causing any failure. I tend to agree with the fluid not being the cause unless it's never changed. But I guess I can't argue with it coming out discolored, but that may also be just an indicator of the failed parts contaminating the fluid.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
If I were to do so... because I have had clients insist on using it... I would use a higher weight than 75-90.
My overall recommendation for any performance build, strip use or not, will always be a straight weight 140... or from what is available in a full syn... an 85-140 like what is available from Torco or Amsoil.
Originally Posted by MannyZ28
Well...how about synthetic fluid for just average non drag strip use?
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Originally Posted by 2 fast 2000
As far as the rear goes, I've learned my lesson
and will never stick that sh*t in my rear again!
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
