12 bolt bearing HELP asap
Old Sep 3, 2002 | 05:52 PM
Chad00ws6's Avatar
Default 12 bolt bearing HELP asap
I just took my axles to have the bearings and exciter rings pressed on and the bearings pressed on also.
Well the as the guy was pressing the bearing on the second axle he realized that he had put the backing plate on backwards. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> Well guess what he tried to press it back off and he busted the bearing in half. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Is there anywhere someone knows I can get one of these bearings or will I have to get another one from Moser? It has the 33 spline axles. Any and all help will be greatly appreciated.
Old Sep 4, 2002 | 06:05 AM
Chad00ws6's Avatar
Default Re: 12 bolt bearing HELP asap
glad someone could help <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> Come on guys I know that someone has to know this.
Old Sep 4, 2002 | 06:09 AM
Silver Slayer's Avatar
Look on the bearing, there should be a set of numbers on it. Go to any auto parts store and they should be able to find the equivalent to that bearing. Good luck.
Kevin
Old Sep 4, 2002 | 09:18 AM
Chad00ws6's Avatar
Tried that but Moser uses a special bearing that no one has. But I finally got in touch with Moser and they said use a regular FORD bearing, it just won't have the o-ring on the outside. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> I know they did not say the "F" word. Oh well I guess as long as it works it will be ok.
