DANG thrust angle
Old Feb 27, 2007 | 06:01 PM
my number 1 hater's Avatar
Default DANG thrust angle
I am having a rearend thrust angle problem... + 20 deg pos on the driver -18 deg neg on the pass... will adj rear lower control arms fix this ????
Old Feb 28, 2007 | 02:58 AM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
Yes adjustable arms will allow you to align it correctly. Was your car in an accident?
Old Feb 28, 2007 | 09:54 AM
lilmommaLS1's Avatar
I can answer this question for u... His car has not been in an accident. It has 180,000 miles, spray, and slicks he said that JUST MIGHT tweak the rear end a bit...
Old Feb 28, 2007 | 03:48 PM
jimmyblue's Avatar
Moderator
18, 20 degrees thrust angle??? That just does not
seem real to me. Angles are usually a degree or less.
Old Feb 28, 2007 | 04:15 PM
LS1Tech Sponsor
He might have forgotten the . ?
With 180,000 miles on the car I would think an upgrade would be probably the smartest thing to do.
Old Mar 1, 2007 | 10:44 AM
I did, all new ... but i did not pop for the adj lower....
