Stop TA Performance diff cover leaks?
I've tried RTV as the gasket. The paper gasket from TA with RTV. Have put pipe thread tape on all the bolts, filler plug, drain plug, and main cap bolts.
This thing still leaks. Any ideas?
I always clean the covers down with brake cleaner and rtv the oad bolts so that don't seep, I have yet to have a drain or fill seep, jut keep them tight. As for the cover surface, I always clean with brake cleaner and use a scotch brite clean up disc on a die grinder to smooth and clean the surface.
Mine seeped slightly around the load bolts until I took it off cleaned everything real well and used a bit of RTV around them.
I did notice that the threads on the cover for the load bolts start about 1/2 inch inside the cover. I think I might have missed that the last time and did not apply thread tape down the bolt shaft far enough.
I purchased Permatex high heat thread sealer this time and Perm High temp RTV silicone gasket maker. I will apply the gasket maker to both sides or the paper gasket and let the thread sealer set up for a few minutes on the bolts.
Hate to install all this and have it start leaking again.
I've installed several of these covers, and never have had them leak using this procedure. remember... surfaces have to be clean and dry to make rtv effective. best way is to use scotch brite surface pads and brake cleaner.
I let the cover sit for 5 days after sealing it up. I then waited 3 days after applying the thread sealer to the fill plugs after I filled it. I also relocated the vent tube on the diff housing to a chassis mounted vent using fuel line.
part number please??
One time a few months ago I went to the dealer and had him pull up the view of the rear components. He asked me what I needed and I said "All of it". He laughed and repeated himself. So did I, "One of everything please". Then I appologized and said my mistake, I need everything but the rear differential. This went on for a few minutes until the parts manager came walking by and greeted me (knows me) and asked what I was working on now. I told him: "The rear end of the car". He said: "Great, should we just order one of everything like we did for the front last time?". The new parts counter guy dropped to the floor, then got up and started typing the order.
So, I have no idea what the part number is. All I know is how to point on the screen and say "That thing right there" or say "All of it". I appologize.
