howl sound?
Old Mar 5, 2007 | 08:52 AM
therobman's Avatar
Default howl sound?
i didint know where to post this so im posting it here i have a 2000 trans am a4 with 35000 miles and when im in like 4th gear at like 2,000 rpms and i tap the gas i hear a howl sound like comming from the back of the car it also happens when i slow down anyone have a clue why and i dont have gears in it yet
Old Mar 5, 2007 | 07:08 PM
iroc85blu's Avatar
one of 2 reasons. either pinion bearing is excessively worn and starting to howl. Or in my case last spring your ring or pinion gears teeth are starting to crack. My ring gear had 6 teeth that were cracked when i tore it down. The cracks were at the base of the teeth and were hairline thin. That was on the stock 3.23's in my 00 ws6 a4. Now have 3.73's.
Old Mar 5, 2007 | 10:58 PM
00BlueTA's Avatar
I would try changing the fluid first, and when you take the cover off look at the teeth to see if they are worn. If you see nothing wrong and it still makes noise take it to a shop to check the pinion bearing and the runout.
