Replacing axle shafts
Old Mar 11, 2007 | 03:57 PM
RoadHazard's Avatar
Default Replacing axle shafts
I am looking to replace my axle shafts with the ones from Moser because the stock ones are pitted badly. I wonder if I can reuse reluctor rings and wheel studs from the stock axles. And if I can reuse these parts, how hard is it to swap them out from the stock axles?
Old Mar 11, 2007 | 11:18 PM
Studytime's Avatar
Yes you can reuse them. You can hammer your old wheel studs out and you can press the reluctor rings off.
Ben T.
Old Mar 12, 2007 | 06:37 AM
BlackScreaminMachine's Avatar
Internet Mechanic
you can use a screwdriver to get the rings off too but a bearing press to get them back on. I fould just put new studs in the axle, they are not that expensive.
