9" Pinion seal leak
I have a center section from Scott @ DLS, and I have a pretty good sized pinion seal leak. I am not sure if you can just pull the yoke off and replace it or if it's more involved then that? It seems to get worse after I race, I don't really ever notice it unless it's after the races, but that's usually when I am lookin under the car is after the races. Anyone else have this issue or know if it can be replaced easily? What part # do I need for napa?
Nevermind, got ahold of Scott and said I can just remove the nut on the pinion yoke, mark it before hand, replace that seal and try to get the nut back down to the same spot.
Oh and pinion seal part # CR 18264
