12 bolt install?
I guess what im asking is, is there alot involved in putting one together and if so is the 450 a reasonable price?
This is about to throw me over my budget, i almost wanna do my heads and cam first but i dont wanna worry about this thing at the track
A Moser rear is shipped two days after the order is taken, where most other companies take three to four weeks. Bob
Mine did come with the axles out but again due to the bearings having to be pressed on after the brake hardware goes on.
Now to have the bearings pressed on i jut take the backing plates and the axles to a shop and tell them? And also what is this u joint adapter i need for the driveshaft and does that need to be installed by a shop also?
Approximately how much did shipping cost for you guys and how long did it take to get to your house after it was processed?
I paid about $180 shipping. Strange took about 5 weeks to get mine to me.
I've installed a Moser and a Strange in the apst 6 months. The Srange is more complete and far easier to do, and here's the differences-
Sway bar mount-
Strange-reuses stock hardware and supplied nuts and bolts, fits perfect
Moser-pay another $70 for brackets and another $20 to get the bushings that fit the brackets. Or just try to half *** it with exhaust clamps. Either way be sure they're on streight or you'll put a twist in the sway bar and preload the rear suspension.
Brake lines-
Strange- mounts identical to stock rear
Moser- rig it with zip ties because the line tabs are not there. And the bolts that held the lines to the stock pumkin- you'll have to make some new holes to use them.
Torque arm-
Strange- Uses stock through bolt style. Put a wrench on the top and hit the bottom with the impact gun.
Moser- Uses 4 bolts. Have fun trying to tighten the top bolts with the floor pan and every thing else in the way. Be ready to retighten them often- they like to come loose and fall out.
Bearings-
Strange- comes installed. The rear is full of fluid. Plug and play.
Moser- pull the thing apart, press you own bearings, reassemble.
Put a 12 bolt into a early Chevelle, Nova, Camaro, etc and you can beat the crap out of it, and not hurt anything. Put one into one of our cars with a torque arm, make a couple 4000 to 5000 dragstrip launches, and I can just about guarantee you'll pick up gear noise. If it is a drag only car, you'll never know or care about the gear noise. Drive your car home from the track, and the noise will drive you nuts. I feel the torque arm stresses the 12 bolt housing, causing distortion. We have never seen this happen with the 9 inch housing.
Exotic Performance Plus strongly recommends the Moser nine inch. This rear is even tougher than the Moser 12 bolt, and the horsepower of the late model F Body cars keeps escalating every year, which requires a very strong rear. With the recent introduction of the 6.2L GM aluminum block and the excellent flowing 6.2 litre heads, the horsepower of these cars is going to just keep climbing at a very fast pace.The nine inch will handle the power, plus we prefer the way the torque arm is bolted to the nine inch in the same way the oem rear-end is attached. (This is the only good thing about the stock 10 bolt...) The Moser 12 bolt uses four short bolts to attach the torque arm, and they have a habit of loosening up, even when loc-tite is used. Why the nine inch is stronger than the 12 bolt. The 9-inch has an internal rear-pinion support that also supports the gear end of the pinion to limit gear deflection under high torque loads. This seems to be the major reason why the 9 inch doesn't start whining after high rpm clutch dumps, when the 12 bolt will pick up noise.The 9-inch locates its pinion gear lower on the ring gear to improve tooth contact, than the 12 bolt does.The 9-inch has a 0.125-inch larger ring-gear diameter and internal pinion support than the 12 bolt does. This is not much of a difference, but it is worth noting.
http://www.exoticperformanceplus.com....html?item=145 Bob
I have not done a 9" install. Does Moser's 9" give you a place to mount the brake lines & sway bar? What setup do you have to do to it before its ready to roll?
