True trac in a 9 inch???
Old Mar 15, 2007 | 08:21 PM
Enforcerws6's Avatar
Default True trac in a 9 inch???
How many of you are running one of these and what do you think of it.
Old Mar 15, 2007 | 10:04 PM
Phillymu's Avatar
I got one, and it works fine
Old Mar 16, 2007 | 07:20 AM
FungusMungus05's Avatar
What was the method you used to break it in so you don't get any noise or whine?
Old Mar 17, 2007 | 02:07 AM
Mighty Whitey's Avatar
I've got one in my car, and love it... the guy that sold me the parts for my center section told me to heat cycle it 3 times: meaning, drive 10 or 15miles down the road, and let it cool off (like you were going out to eat or a movie) then do the same 2 more times.
after that, he said drive it like you plan to from there on out.
never had a problem, nor do I have any horrible whining from it either.
Old Mar 17, 2007 | 04:42 AM
EPP's Avatar
EPP
The True Trac is a really good unit, so much so that Eaton bought it from Detroit! Bob
Old Mar 17, 2007 | 06:33 AM
import slayer's Avatar
I have one in my 9'' and it is really good.
Old Mar 17, 2007 | 08:02 AM
NumberOneSled's Avatar
I have one in my S60 and so far so good.
Old Mar 17, 2007 | 11:06 AM
99blancoSS's Avatar
9" w/tru trac here as well. Love it.Bob at EPP or Scott at DLS can hook you up with one. I got mine from DLS. Break in instructions were 3 trips of 15 miles no faster than 60 then one trip of 150 miles no faster than 60 . Then it should be ok. Your heat tempering (the face of the gears?) so you want mild heat then greater heat with proper cool down in between cycles. The easier you break it in the better off it will be is what I was told.
Old Mar 17, 2007 | 11:10 PM
white mongoose's Avatar
have one on my 98ss m6 on the bottle dumping the clutch at 6xxx and its holding like a champ thanxs drive line solution ill b getting a video of my car in the track my 60 is 1.37 so verry happy
