ford 9 inch Bearing Caps
Old 03-21-2007, 05:54 PM
2001blackta's Avatar
Default ford 9 inch Bearing Caps
Can the bearing caps on a ford 9 inch be replaced on the center section?
Old 03-24-2007, 12:13 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
no... unless you get real lucky. the bearing bores are machined to an assembled case, along w/ the threads for the adjusters. chances the threads wont line up, and the bore will be off.
Quick Reply: ford 9 inch Bearing Caps
