Identify my problem, please. Sound clip
Problems:
- It makes this noise...
Sound clip
- Under hard turns, I can hear my driver's side rotor making contact with something and squealing a bit.
- I haven't measured it, but the wheels have a bit of play in and out.
C-clips wearing out, maybe? Bad differential? Bad bearings? All of the above?
I found some related threads, but I want to be as sure of the problem as possible...
In and out play is definitely more then ~1/32".
(Plus parts)EDIT: Checked mine for play and found nothing odd. Bad bearing nonetheless. The point at which you feel play is the point at which you need to give Moser a call...
