View Poll Results: Which driveshaft is stronger?
Stock steel
13
56.52%
1LE Aluminum / LS1
10
43.48%
Voters: 23. You may not vote on this poll
Old Mar 26, 2007 | 06:50 PM
Jeff 97 Formula's Avatar
Default Which driveshaft is stronger?
Currently have the stock steel shaft and am wondering if I should swap it out with something else. Thanks!
Old Mar 26, 2007 | 07:46 PM
KCFormula's Avatar
Its the yoke that will break first, not the Driveshaft itself. And I believe the Yokes are the same between the two.
Old Mar 26, 2007 | 08:50 PM
INMY01TA's Avatar
I beg to differ. I don't know who thinks the aluminum one is stronger than the steel one but it's not. I've seen this happen lots of times.
Old Mar 26, 2007 | 08:58 PM
tbird31's Avatar
HOT DAMN!
Yea i've seen that happen a few times. I'd have to go with steel though lol...either that or a heavy duty one, but they are usually $$$...
Old Mar 27, 2007 | 03:59 AM
EPP's Avatar
EPP
Here is the one I recommend, which is lifetime warrantied! Bob
http://www.exoticperformanceplus.com....html?item=541
Old Mar 27, 2007 | 07:22 PM
koolaid_kid's Avatar
Another choice is the Spohn Extreme Duty Chrome Moly driveshaft. Just my opinion (and what I use).
Old Mar 28, 2007 | 05:05 PM
John35thSS's Avatar
Spohn Top Gun here, Its a work of art. The driveshaft welds are so good they have to be seen I clearcoated mine.
John
And the stock steel definately stronger than stock aluminum, have seen 3 aluminum twisted in half.
Old Mar 28, 2007 | 07:34 PM
KCFormula's Avatar
http://i83.photobucket.com/albums/j3...100_0076-1.jpg
Now that I think about it, a friend of mine had his shaft break before the yoke also. (stock LS1) (I'm an idiot)
I have just seen a lot of yokes break when people upgrade the shafts but not the yoke.
Old Mar 30, 2007 | 07:12 AM
brownie_ta's Avatar
does anyone know if the yoke is different between a lt1 with an m6 and an ls1 with an a4? We want do swap them to see if the steel ds is bent or out of balance but dont want to go through the trouble if theyre diff.
Old Mar 30, 2007 | 09:25 PM
letsrun97z's Avatar
i swapped my steel out for alum because i couldnt get it to balance out and couldnt do over 80 becasue the shake, i def like the alum
Old Mar 31, 2007 | 08:35 PM
Silas2k's Avatar
ive always been under the impression that the steel drive shaft is stronger but the aluminum drive shaft is lighter... and the cf one is strongest and lightest but really expensive
Old Apr 1, 2007 | 10:17 AM
I was just curious since it seems everyone's upgrading from steel to aluminum mostly due to the unbalanced steel shafts, and the 1LE is lighter. I must be one of the lucky few that has a balanced steel shaft since I experience no shake at 80+ (although I do get a lil wheel shake occasionally, but I think that's due to me getting the weights on the inside of the rims).
But after seeing the pics in reply #3 and #4, I think I'm gonna stick with the stock steel if the steel is stronger than aluminum, and I do no experience issues with the stock shaft.
Old Apr 1, 2007 | 12:25 PM
BlackScreaminMachine's Avatar
Internet Mechanic
neither, aftermarket steel like Denny's but if I had to choose id get a LT1, 1LE DS
Old Mar 5, 2008 | 08:05 PM
Cumbias's Avatar
Denny's make a great steel driveshaft with an unlimited warranty. If you ever manage to break or bend it, they'll replace it for free.
Old Mar 5, 2008 | 08:25 PM
Jays00ss's Avatar
I would say neither, I just bought a Strange 3" chromoly With 1350 yokes and u-joints through Eric at Midwest On monday for $295 shipped. Thats about the best bang for your buck you will find.
Old Mar 5, 2008 | 10:50 PM
GregWS6&z28's Avatar
i think the steel is stronger
Old Mar 6, 2008 | 09:08 AM
Black02SLPSS's Avatar
HA! Im the tie breaker
Old Mar 7, 2008 | 02:45 AM
gold98Z28's Avatar
seem many a stock al take a **** in m6 cars, but hold up decent in a4 cars. i ran my al and keep a stock steel one on hand at the track just in case.lol but it didnt **** at the track but rather on the way home from work in rush hour on a bridge no less. but it had help from the tq arm rapping around it.
Attached Thumbnails Which driveshaft is stronger?-broke-004.jpg   Which driveshaft is stronger?-broke-003.jpg   Which driveshaft is stronger?-broke-002.jpg
Old Mar 7, 2008 | 07:02 AM
Nice carnage. What torque arm were you running?
Old Mar 7, 2008 | 10:00 AM
Jays00ss's Avatar
That is precisely why I just bought a new Strange Cromoly one. I might not have all the HP in the world (440 RWHP) but I don't want this kinda crap happening.
