how big gear?
Old Sep 22, 2002 | 07:02 PM
blackend02's Avatar
Default how big gear?
just wanted to know what was the biggest gear you can run and still retain your stock abs and traction control?
Old Sep 22, 2002 | 08:54 PM
Chad00ws6's Avatar
Default Re: how big gear?
You should be able to run whatever you want. I have 4.10 but the gearing does not affect the ABS or the Traction Control. I see you have a 2002 and it should be the same as my 2000. The ABS and Traction control both work off of exciter rings on the axles out by the hubs that has a megnegtic pickup. Gears would not affect this at all.
What I am saying is for a 4 channel set up. Look under your car at the rear wheel. If there is a small plug on the backside of the hub behind the axle with two wires running in to it you have a 4 channel set up. I know this because I just put a whole new rear in mine. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> But boottom line is the gearing will not affect either.
