ST3800 vs TP4000
I am concerned that the TP4000 will be too much around town as I drive my car mostly everyday. I don't mind the SY3500 at all and some people classify that as "loose". I think it's fine. Another concern is heat... I can't get a trans cooler since I have a ram air setup. Currently, my SY3500 has no problems.
Any advice??
-Jim
<small>[ September 17, 2002, 02:14 PM: Message edited by: key master ]</small>
Personally I would do a trans cooler over a ram air unit anyday. Any power gained from the ram air will be negated by excessive tranny heat. Plus trannys are expensive!
I've been told that the PT4000 would roughly feel like my current SY3500 around town... sounds good to me.
How would I "remotely locate" my ram air??? Or did you mean remotely locate the cooler? If so, where if not right in front of the radiator?
-Jim
Also you could do it in a location that doesn't get much air and make your own ram-air with some tubing from home depot to get some air across it. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<strong>Why would a PT4000 be better from a roll? More efficient? Or simply because it has a higher stall?
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">YTP 4400 is more efficent and has a longer shift extension.
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not a chance. I've driven both and the YTP 4000 is definitely looser. The extra STR does not negate the extra 500 rpm of stall. Plan on using another 300 or so rpm around town.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have a cooler with FTRA, its no big deal. I mounted a 16000 GVW on the side of condensor and use the FTRA to pin it in place on one corner. You could also mount it off to the side, using the "Dope" method (I hope I got the right guy <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> ). You NEED a cooler, even with your SY 3500.
<strong>You NEED a cooler, even with your SY 3500.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I only see max TFT around 205 or so with my SY3500+3.73s and no cooler even during the Texas summer, usually much less like 180-190. I understand the cheap insurance idea, but why do you say you need one? Mike seems to discourage the "need" notion too. What am I missing?
If you start flogging a high stall converter on the street, or at a road course, or by hot lapping, the tranny will get too hot. Even an efficent converter generates a lot of heat if you keep it in the rpm band where it is generating torque multiplication and running at high rpms.
I try to keep mine in the 160* - 180* range.
Raising your part throttle shift points with edit will help tighten things up.
Now, will the ST3800 feel much looser than my SY3500? I would think it would feel tighter because of its higher STR with only 300 RPMs higher (3800 - 3500 = 300). Would that be a true statement?
I really don't want anything looser than my SY3500, I think it approaches my street limit of looseness, even with my 3.73 gears.
-Jim
