Another 416 cam question
Old Sep 26, 2024 | 05:58 PM
old motorhead's Avatar
Default Another 416 cam question
I am in need of a little wisdom from folks that have been there and done it. I'm planning to build a 416 LS3 for my C6 this winter. Here's what I have to work with:
*LS3 block
*LS3 heads CNC ported by Tx Speed milled .010 (can mill more if needed). Absolutely not interested in spending big
money on cylinder heads. What I have now is what I'm going to use. I have access to good quality 93 octane fuels.
*LS3 intake mani ported and rod modded by Gwatney.
*1.875" Kooks long tubes with 3" non catted mid pipes and Corsa Sport Z06/ZR1 mufflers.
*Not sure on the rotating assembly but it will be all forged and shooting for static compression ratio around 11.5:1.
I guess my main questions revolve around cam selection. My current cam, with SBE LS3 is a 226/234 115+4 with .620 lift on both sides. Through milling and thinner head gasket, the static CR is around 11.3:1. It pulls really nice from idle to 7K rpm with a Pat G tune. Manners are excellent. I have no interest in compromising manners to get a few more HP.
So, what cam specs would you suggest that would make significantly more power with a 416 while retaining the manners I have now? How much overlap in a 416 would be similar to 0 overlap in a stock cubed LS3 as far a manners go? I'm comfortable coming up with cam specs for LS2/3 engines. Clueless for the bigger engines.
Help appreciated.
Old Sep 26, 2024 | 06:23 PM
I would present your questions to Mr. Tony Mamo.
If anyone could keep an engine mild-mannered while shoving more cam into it, it would be him.
He would know where to go up on the cam while minimally affecting manners, if at all.
I'm not saying he works motor miracles, but he seems to do it regardless.
Old Sep 26, 2024 | 06:57 PM
I personally would not have the heads ported. The LS3 ports are plenty big enough…almost too big…to support what your doing. You can easily go 12:1 with 93 pump gas. Compression adds torque and efficiency. Just wrapped up a C6 build here, that we went 12:1 on. Pump 93 and it runs great. Zero knock. I also would not go crazy on camshaft here either. Consider a 232/240ish camshaft with the same .620 lift you’re currently running on a 114+3. Just my 2 pennies here…
Old Sep 26, 2024 | 07:25 PM
The heads are already ported by Tx Speed. They are running on my SBE LS3 now. My wild assed guess cam specs were a 232/242 115+ whatever it took to get to mid eights for a DCR. Current cam is .620 lift and has 50+ thousand miles with nothing more than a valve spring and rocker arm swap at 30K miles (BTR platinum duals with new stock LS3 rocker arms). Not too far off from your suggestion and also grinder11's as far as cam specs go.
I know Mamo would be the go to guy for cam help. I'm just afraid he would talk me into some high dollar heads. I'd rather keep that money in house. I know HP wouldn't be what it could be. I'm OK with that.
Upping the static to 12;1 sounds good to me.
Old Sep 26, 2024 | 10:13 PM
Vega Racer's Avatar
236 248 @50 620 603 113+3 Made 515 to the wheel on a super safe tune, Now I need more,lol.
Old Sep 26, 2024 | 10:22 PM
grubinski's Avatar
16 degrees of overlap… too much for the OP. He has zero overlap on his current 376 cubic inches. I’d guess maybe 6 degrees of overlap would drive the same on a 416, but that’s just a guess.
Old Sep 27, 2024 | 06:44 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
235*/243* 115*+3* .621"/.604"
Will run great @ 12.0:1 & Pat G. Tune
My .02
Old Sep 27, 2024 | 09:34 PM
grinder11's Avatar
This is pretty much what motorhead and I thought. We figured the 416 will swallow a 6° overlap increase with no problem. We also figured the 232°/240° duration and keeping the same 620" lift Scott mentioned. A 416 is only 1.5 cubes/cylinder less than my 427. I ran a 232°/250° 112° LSA in my A4 C5. I think most people here would be rather surprised at how civilized it drove. IDK what trans OM has in his C6. Guess we were pretty damn close, OM!! Time to start the parts gathering, and down the rabbit hole you go!!!
Old Sep 28, 2024 | 01:39 PM
My .02
Is that a shelf cam or custom? It will definitely have a Pat G tune (if he's available). He's not but a little over two hours away from home. Little to no city driving between he and I. I like it that way.
Old Sep 28, 2024 | 01:49 PM
I'm running an M6 transmission. Not allergic to auto transmissions. I just fell in love with the manual 60 years ago when I drove my first one on the farm. Chevy pickup with three on the tree. I'll probably need some help with the rotating assembly too. Rabbit hole dive will start pretty soon. Appreciate all the help
Old Sep 28, 2024 | 10:06 PM
Abs's Avatar
Abs
I say the summit cam in this thread. It's the 8710: 230/242, .625, .605, 113+3. Has overlap of 10 but an awesome torque curve and good driving manners in this ls3. Should be even better in a 416.
https://ls1tech.com/forums/dynamomet...o-results.html
Old Sep 30, 2024 | 06:31 PM
LSleeper1500's Avatar
My combo will be 416, FED Stage 2 ported head, 12.0:1 compression, and GPI ss416 cam. 242/258. May run good, may run like sh*t. Time will tell 😂
Old Oct 1, 2024 | 06:25 AM
That's a little much for me. Good luck with it
Old Oct 1, 2024 | 07:29 AM
84ta406's Avatar
If Pat G. Is doing the tuning, why not have him spec the cam too? He's always put together good combos.
Old Oct 1, 2024 | 10:49 AM
I would love to get Pat's thoughts on this. On his website, he states that he doesn't make cam recommendations any more....unless something has changed that I'm not aware of.
Old Oct 1, 2024 | 01:24 PM
84ta406's Avatar
I would think a recommendation and buying a custom spec cam from him would be different but who knows. That would be the path I take. same thing I did with Tony Mamo. People don't give him enough credit for it but Tony is VERY good at custom spec'ing a cam. Wouldn't hurt to talk to Pat G. over the phone or email though. I would specifically mention you want to buy, not just fishing for specs though.
Old Oct 1, 2024 | 07:00 PM
grinder11's Avatar
Probably doesn't make cam recommendations anymore due to someone raising Hell with him about a cam he spec'd for them. One thing about cams that I do know, and know you do, too, is that you have to be honest with yourself as to what you really want, and how you'll use the car. I'm guessing that someone was dreaming about a race car they'll never have, and told Pat they'll be racing it every weekend, and one or two days mid week. Probably left out the daily driver part, and he ended up with a bucking bronco nobody could tune, and he blamed it on Pat. My .02.....
Old Oct 1, 2024 | 07:53 PM
[QUOTE=grinder11;20579297]Probably doesn't make cam recommendations anymore due to someone raising Hell with him about a cam he spec'd for them. One thing about cams that I do know, and know you do, too, is that you have to be honest with yourself as to what you really want, and how you'll use the car. I'm guessing that someone was dreaming about a race car they'll never have, and told Pat they'll be racing it every weekend, and one or two days mid week. Probably left out the daily driver part, and he ended up with a bucking bronco nobody could tune, and he blamed it on Pat. My .02.....[/QUOT
You can't make everyone happy. Some will criticize a certain set of specs based on their experience with exactly one cam and one tuner. I try to listen to the guys that have been there and done it multiple times over multiple years on multiple platforms. I've been around long enough to know how to sift through the BS. You know EXATLY what I mean....
I went to Pat's website today. He offers his services as a build consultant. Charges a little more than he did for just cam specs. What he charges if very reasonable compared to what could happen if you make even a minor mistake (preventable with knowledge) in your build.
Old Oct 1, 2024 | 08:59 PM
grinder11's Avatar
[QUOTE=old motorhead;20579301]
I agree 100%.
Old Apr 12, 2025 | 01:08 PM
Rich2342's Avatar
*LS3 block
Help appreciated.
What Cam choice did you arrive at?
I am planning either a 427 or 416. I know what works in a 427, but not in a 416. I am aiming for a perfect balance. At least 530whp, but want 500wtq in the mid range. My current LS3 manual with cam with 3.91 gears has 19 degrees of overlap. Looking to knock that down some with the 416 but also make a good bit more power and torque.
