new gears
Old Sep 23, 2002 | 09:32 PM
ed f's Avatar
Default new gears
installed new gears,4.10 in my 98z it has some whining.is this normal.i went from a factory 3.42 with a m6 tranny.i like the take off and rpm range better for every day driving.i realy could not use 6th gear befor[legaly].i had bad 60 times and i could take off at no more than 1800 rpm's and even with drag radials i was limitted to 2400rpm's.my best time was a 13.65 at 103.5 mph.i seam to launch much better with less wheel spin.i have 255/50/16's on the back.i would like to find out what aprox max mph in 4th gear.thanks for any help you can give me. ed f
Old Sep 23, 2002 | 09:37 PM
Ragtop 99's Avatar
Default Re: new gears
If your gears are whining from the beginning, either they were not installed right or you did not properly break them in.
speed in gears:
http://www.f-body.org/gears/
If you not correct your speedo, your odometer is reading 20% high, racking up extra mileage.
Old Sep 23, 2002 | 10:26 PM
wrencher's Avatar
wrencher
Slight wine might be unavoidable but is it real loud at 60mph? This is a 10 bolt right ?
Old Sep 24, 2002 | 06:19 PM
ed f's Avatar
THE WHINNING IS NOT BAD.I CAN LET OFF THE GAS AND THE WHINE GOES AWAY.IT'S JUST DURING ACCELERATION.I DID ADJUST MY SPEEDO WITH MY HPP3.THE SPEED SHOP I GOT MY GEARS FROM DID NOT SAY ANYTHING ABOUT A SPECIAL BREAK IN PROCEDURE.I HAD TO HAVE GEARS INSTALLED.I AM A DISABLED VET.I CAN NOT DO ALOT OF THE MECHANICAL WORK MYSELF.I HAVE TO RELY ON OTHERS.SPINAL INJURY.THANKS FOR ALL THE HELP. ED F
Old Sep 25, 2002 | 05:35 AM
ZR2877's Avatar
I also have a 98 Z28 M6 and just put in the 4.10s. I have a slight whine in mine I have learned to deal with it. I,ve talked to alot of people said its normal. I love the difference in acceleration. I've heard that richmond gears whine more than the rest motive and GM tend to have less whine . Next time you get a chance there is a great track down here in Ga in reynolds called silver dollar and it will get you some good times. Normally 3tenths quicker than the track in north Ga. Your car should be in the 12s down here. I beleive it has alot to do with elevation and probably good traction down there at silver dollar. Good luck runnin them gears.
Old Sep 25, 2002 | 06:46 AM
ed f's Avatar
thanks for the info.I was stationed at FT Gorden thats in the city of agusta.I was there in 1985 for some electronics school while in the army.Ihad a 70 1/2 Z28.there were tons of nice cars.Do you live near there? ed f
Old Sep 25, 2002 | 07:34 AM
02Z's Avatar
02Z
I have 4.11's and have some whine. From what I read the break-in period is 15-20mi under light load then a cool down period. After that stay off the throttle for 200 miles. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ September 25, 2002, 07:58 AM: Message edited by: 02Z ]</small>
Old Sep 25, 2002 | 01:22 PM
ed f's Avatar
