Anyone running a spool with 4ch ABS???
Old Sep 26, 2002 | 05:28 PM
SPANKY LS1's Avatar
Default Anyone running a spool with 4ch ABS???
If so, what happens, does it still work, do you have a constant ABS INOP light, or what? TIA, Shawn
Old Sep 26, 2002 | 10:01 PM
SSINFUL's Avatar
Default Re: Anyone running a spool with 4ch ABS???
I dunno. Mine is showing up next week w/ the Posi. I don't know that the ABS (in the F-bods) has anything to do w/ the diff.
Why wouldja wanna go w/ a spool? Sure would make a hella racket around every corner...
Old Sep 27, 2002 | 09:54 AM
ROB'S SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SSINFUL:
<strong>I dunno. Mine is showing up next week w/ the Posi. I don't know that the ABS (in the F-bods) has anything to do w/ the diff.
Why wouldja wanna go w/ a spool? Sure would make a hella racket around every corner...</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">are you sure you know what a spool is? a spool is a solid union between the 2 axles. no springs, no gears, no clutches. it wont make any noise when cornering. your tires will hate you though. as far as abs is concerned, i dont think you can use abs with the spool. but dont quote me on that.
Old Sep 28, 2002 | 10:14 AM
SSINFUL's Avatar
Yeah, Robbo, I know what a spool is. It's called not having a differential.
As far as noise, I was referring to the fact that ya would always be dragging one tire (the inner) around every corner. Not very good for handling or tire life. Or for trying NOT to get attention from the gendarmes...
Old Sep 28, 2002 | 10:21 AM
SPANKY LS1's Avatar
You wanna hear noisy, try a Detroit Locker. I had a Locker in the 9" in my last car (2000 Z28 A4), and it was horrible, I changed to a spool, and it was silent, very stretable. The whole tire chirping thing is overly exaggerated, IMO. I drove around with a spool quite a bit, and on radials, it's pretty quiet, not to mention the tires (radials, that is) did not wear out noticeably quicker with the spool than with the locker. The only time the tire dragging eve became an issue was in a tight turn, such as a u-turn or turning into a diveway or parking place. My concern is this: In my old car, I had 3 channel ABS, which wouldn't work with a 9", anyways. Now, I have 4ch, and can make it and my TCS work with the 9", but what will happen to the ABS? Will it work, not, or some of the time?
Old Sep 28, 2002 | 08:17 PM
ROB'S SS's Avatar
<strong>Yeah, Robbo, I know what a spool is. It's called not having a differential.
As far as noise, I was referring to the fact that ya would always be dragging one tire (the inner) around every corner. Not very good for handling or tire life. Or for trying NOT to get attention from the gendarmes...</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">hey man, didnt mean to insult your intellegence, but the way you worded it made it sound like you knew not what you were talkin' 'bout <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
