DAMN these 4.10's kick ass!!!!
hey i got a 2002 z28 its only got a cold air intake and a cat-back exhaust and 2.73 gears in the rearend and i ran 13.15 @ 107 mph and 1.9 at 60' first of all is that good and i just bought some 4.10 gears...wat should i be looking at for times?
Relo brackets, shocks, and pinion angle @ -1.5*. With 315 DR's, if you don't get traction with the above, something is bad wrong. There are folks who are running taller 4.56 gears with 315 BFG DR's and they get enough traction to pull the wheels out here on the streets. You have the have a good suspension setup.
Unfortunately for me they don't make DR's in big enough sizes to fit my wheels, that and the fact that most of the stuff that improves traction off the line isn't then same thing you would do for handling. I don't drag race so I will just have to put up with the traction issues!
i got 315 bfg drags and am still loving the 4.10's they are actually quieter than my 3.42's i should of taken it easy on them tho, i couldnt hold in for the 500 mile break in period.
but deff worth it, its amazing seein the speedo climp faster and the whole car jsut squat and go.
you just gotta be quick with the shifts and not be bouncin off ur rev limiter due to bald tires or anything.
I see you have 17" wheels, what does your 4th gear top out at? Im gonna be running a 150 shot making 500wheel and in the feature maybe 560+ with Cam, and im afraid im gonna have to shift to 5th in the 1/4. and maybe rob my top end too much aswell.
I konw you dont want to hear this but i wouldnt go to crazy with that 6speed with the little 10bolt with sticky tires !! Ask how i know? i would put some money aside and start saving for the 9in becouse it will be coming soon.
#32
#33
Originally Posted by walt spangler
How do I Know if my car has 4:10's??? if it was special order, would it be on any documentation? 02 SS LE 6spd (for sale) In maryland. Thank's..
#35
Originally Posted by 1redta
I don't think any one here as enough horsepower to top out a M-6 car with 4.10's so I wouldn't be worried about topping out the gear
#36
Originally Posted by BIG_MIKE2005
I cannot believe I just read this. Your kidding right?? I know several people on here with enough power to top out a set of 4.10 gears in about 15-20 seconds.
Unless you meant top of 4th. Which is only 112 mph with 4.10s with stock tires and limiter. So in that case every car on here can top out under 15ish seconds
#37
Originally Posted by Ericbigmac83
Wow, i dont know alot of cars that can hit over 245 mph that quickly, Assuming a 26" tire, 4.10's and 6500 rev limiter..........
I didn't know 4.10 gears in 6th gear would go that high for mph. I was under the impression the higher gear you go the less top end you have. Which should mean you could top out all six gears & not be goin as fast as if you left the lower gears in. Or am I confused on how it works. I'm still new to learning about the rear info.
--Edit--
This is what a local guy in our f-body club told me:
"with my 7k rpm rev-limiter i can go about 165 at the top of 5th gear and about 130 at the top of 4th gear...who knows how long sixth would go, if i had the power it'd be WAY up there...LOL"
So I was off on the top speed deal, my bad. But the top speed for 4th gear isn't as low as 112. But thats also with the limiter @ 7k instead of 6.5k. His gears are 4.11 in a 12-bolt rear with heads/cam combo puttin out about 420ish.
#38
Yea, the first 4 & they go very quickly at that.
You are correct about if you were topped out with 4.10s at 6000 rpms, that you would be going a higher speed with the original, higher gears, at the same 6000 rpms. A higher gear gives you higher mph at the same engine speed.
Heres an example,
4.10s at 6000 rpms in 4th gear you would be going 112mph (lower gear)
3.42s at 6000 rpms in 4th gear you would be going 134mph (higher gear)
#40
i beg the differ...i raced a c6 Z all the way to 155, i was pegged...i had 4.10's in my stock 10 bolt....then blew up the rear that day at the track lololol
they died hard!
